Lanier 6725 copier: Paper is always jamming and
Lanier 6725 copier: Paper is always jamming and won't copy anything. Maybe it's time for a new one, but let's see what ya'all know??
  • Office Equip... Expert
  • 422 Answers
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
SOURCE:
Lanier ld040 paper jams
your web fell out, remove fuser,( lift handle on each side), take off web assy 2 screws 1 each side, rewind web and reinstall
Dec 03, 2013 | Lanier Ld 040 With Feed, Print, Scan,...
Very light copy in 2nd side copy
its a moisture issue in the paper. try nice new dry paper and i bet it works fine
Mar 17, 2012 | Lanier Office Equipment & Supplies
Hi have a lanier copier model 6725. When I make copies it makes the copy and then also prints grey across the entire copy. Looks like it is printing old ghost copies...how can I fix this
Hello!
If you say that you see old ghodt copies the problem is with the Fuser Roller in the Fusing Unit.
If this is right i advise you to call a Tech (if you do not have the skills to change it)
See you!
Sep 02, 2011 | Lanier 1205 Copier
Our ld090 copier keeps reporting a jam in the output tray, but there is no jam. We have been told this is a problem with a sensor. What can we do?
If there is no paper inside, maybe the problem is with some sensor. Exit sensor maybe...
But you also can see somethings. Make sure that the doors are well closed. If you have an open switch (door switch) the machine don't change the first message (that is "jam").
Mar 01, 2011 | Lanier Office Equipment & Supplies
Paper load error.
check rollers for free operation and anything that maybe causing it to misalign!!! :) maybe something foreign stuck in it ive had that happen!!!!
Jul 06, 2009 | Office Equipment & Supplies
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
May 28, 2009 | Lanier Office Equipment & Supplies
PAPER JAM IN TRANPORT
IF THE PAPER IS LAYING FLAT ON THE TRANSPORT WHEN THE JAM OCCURS, THE PROBLEM MAY BE A DIRTY TRANSPORT BELT SENSOR. A TECHNICIAN IS REQUIRED TO REPAIR THIS, AS IT INVOLVES DISASSEMBLY OF THE IMAGING UNIT.
Dec 22, 2008 | Lanier 1205 Copier
Misfeed on lanier 7320
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
Dec 11, 2008 | Office Equipment & Supplies
Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Lanier 7328
hi im jules_09,have you tried cleaning all the ruber roller?try cleaning all ruber roller then lubricate al bushing and gears.if there is still a problem check all paper sensor it can be cleaned with alcohol.just soak the paper sensor with alcohol then let dry after a few minute then install it back again in the copier.dont soak the paper sensor in alcohol while it is in the machine.turn of the copier first
Nov 03, 2007 | Lanier 1205 Copier
Open Questions:
410 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
