Whats wrong with the tv have green power button but no picture
SOURCE: TV is connected to cable;
Return it to Amazon.com.Get a replacement tv.This tv have problems with it 1 or 2 long LCD inverter boards,it dying going to be dead.That why u have only a flashes of a picture only a few second,than died,just black screen lelf and have sound.Or talk to Amazon.com customer serviced to get ur tv a warrenty repair.
SOURCE: I am trying to find the logic/video board for my
I am an electronics tech so i know that finding spare parts for a tv can be very difficult. Your best bet is to try to purchase the board from Sansui. If Sansui cannot help you ebay is a great place to find spare parts.
SOURCE: Picture shows for 1 sec when switching on TV, and
Now u turn on the tv the tv pictures only flashes a few sec.than dies,but the tv still have audio sound left only?Yes,mean ur tv have a 1 or 2 long boards that are call a LCD inverter boards are the causes and the problems.These 1 or 2 long LCD inverter boards only job are to provided the tv LCD screen panel for a backlight for the tv to have picture only.Tries websites like Shopjimmy.com,Ebay.com to buy a 1 or 2 the tv long LCD inverter boards for the replacement.
SOURCE: I have a Sansui 42' Hd Lcd Tv. When I turn it
The Backlights inverter, the T-CON,or the 24vdc power supply may have gone out, it will require in-depth troubleshooting. Please read below:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Must have to take the tv aparts.U must have all the tools and understanding basic electronic and also u must able to do basic soldering works too?Yes,u must have to do examining the tv power supply board carefully,that the board where the tv power a/c cord plug into it.U must have check all the tv capacitors components parts,if the tv have any bulges or puffing up any capacitors parts at all will and could causes these problems.U must have to changes all the tv dying and leaking capacitors parts in the tv power supply board will to help the tv power supply board to work correctly again.If u check and examining tv power supply board carefully but have seen none or any dying and leaking bulges or puffing up capacitors parts at all.Than this tv have a 1 or 2 long boards that are called the LCD inverter boards it is dead.These 1 or 2 long inverter boards only job are to help and provided the tv LCD screen panel to have a backlight on the screen to see a picture on the tv LCD screen panel.Must have to be changes 1 or 2 long inverter boards to fixed the tv have sound but no pictures problems.If u can't do soldering work and can't changes capacitors components parts at parts levels.U can tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the 1 or 2 long LCD inverter boards too for the replacement.
