Hello, you need pc or watch tool-set (including mini-torx) Stepps: -on bottom there are rubber-parts, where it stands on: disconnect them (small cutter-knife) -there are srews-torx turn them out -then you can move top-cover with the loudspeaker and the display !! be careful there are very thin wires connecting top and bottom -on bottom there is the board, connected with 2 screws (same torx-type) and a plastic-clip: turn them out and open the clip carefully -side of power button pull out the board (have a look on wire) -now you will see the batterie / accu type BST-37 900mAh (standard to many Sony-Ericsson handys) / can be taken out
Substitute your clark tips for Tweco ones, which are available at all welding stores. Find your nearest Praxair location in the website www.praxair.com.
Part number os TWE 11-30 or TWE 11-35 depending on the size of your wire .030 or .035.
I am having the exact same problem with my vauxhall corsa and my pioneer deh-6000ub its so annoying it works with the manufacture stereo soon as i connect my pioneer in it doesn't come alive (the HCB-400)
you can get that charger aftermarket at radio shack take the walkie with you to get the right power supply the voltage should be close to where the external power plug goes into the radio.
