A "general error" with two red lights blinking on an Epson T60 printer can be caused by various issues, such as a paper jam, a foreign object inside the printer, a problem with the ink cartridges, or a malfunctioning of the printer mechanism.
To troubleshoot this issue, try the following steps:
- Turn off the printer and unplug it from the power source.
- Check for any paper jams or foreign objects inside the printer and remove them if found.
- Ensure that the ink cartridges are installed properly and have enough ink.
- Check if any of the cartridges are damaged or expired and replace them if necessary.
- Clean the print head using the printer software utility or manually.
- Check the printer mechanism for any damages or obstructions and remove them if found.
- Turn on the printer and check if the error persists.
If the issue persists, you may need to contact Epson customer support or a certified technician for further assistance.
