Here you go, in detailed steps:
Hope this helped! ^_^ Have a great day~
my name is wilson gomez i forgot my passcode i pod touch ........................................ can you help me please my emal is [email protected]/yahoo.com or [email protected]
i cant get mine to show the files i already checked hidd. and sys file are showing???
Forgot my ipod touch password
SOURCE: forgot my ipod touch password and now its disabled
Connect to iTunes, go to the settings menu of your iPod (click on the picture of your ipod on the bar on the side.) Then click "restore my ipod's settings," or something similar to that. You will have to re-sync your ipod, but your password will be removed. hope it helps
SOURCE: How do I Unlock Ipod screen if I forgot the 4 digit password?
If its the ipod Touch that is disabled, use Ziphone.
http://www.ziphone.org/
Use the Ziphone ipod touch and iphone jailbreak GUI to put the ipod in recovery mode. Then restore it using iTunes.
to fix this you will need to erase all the data on the ipod(s).
plug the ipod into the computer using the included usb cable. open itunes (if it doesn't open automatically) in the column on the left side of the window there is an icon showing your ipod's name. click on it then click on the button that says "restore ipod"
WARNING: this will erase all the content on the ipod (you can put it back on later)
it will ask you to confirm. hit ok and keep your ipod plugged in as it restores it to it original state. pick the language you prefer and then load your music back on the device
SOURCE: 8GB iPod Touch Disabled
Thanks to everyone who provided solution inputs. I finally have my iPod back. The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version. Good luck!
First you need to read this page and follow the instructions on settings the touch into recovery mode
http://support.apple.com/kb/HT1808
ones in recovery mode you can remove the code by restoreing the ipod with itunes heres how
Restore
How to restore your iPod:
For Windows:
