Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
A
Anonymous Posted on Jun 17, 2014
Does battry have to cool down before charging?Dewalt DC920KA Heavy Duty Xrp 18V Cordless
batteryshopsuk
Level 1:
New Friend:
  • Contributor 44 Answers
  • Posted on Jun 26, 2014
batteryshopsuk
Contributor
Level 1:
New Friend:
Answers
44
Questions
0
Helped
23794
Points
74
Yes, when a battery is being used for a long time, you need to let it cool down and take it to charged. Although there is many fast charger now, but in order to protect the battery, I recommend you to buy a second battery for replace.
And, if you do not know where to find the right one? Here is some suggestion for your Dewalt DC920KA Battery
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Mar 04, 2008
SOURCE: Dewalt 18v. cordless drill
Hope to help.
hope your wife is ok!!
you need to get all the hair out firstly but DO NOT touch the exposed switch as it is a static switch and can fail by the tatic in you!
the problem may be that the brushes were damaged try replacing them see how that goes.
hope this helps. Sean
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 07, 2008
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Anonymous
  • 10865 Answers
  • Posted on Apr 30, 2009
SOURCE: dewalt 18v xrp clutch??
Hello Matt - I recommend that you get your drill to the nearest Dewalt service center. That way you know it will be done right and under warranty. Go to this site to find your closest dewalt service center:
http://www.dewalt.com/us/service/center_finder.asp
Anonymous
  • 2176 Answers
  • Posted on Oct 10, 2009
SOURCE: all i need is the schematic for a dewalt hammer
go to Dewaltservicenet.com and in the middle of the page type in your model number and you can download a breakdown for this tool. If I have answered your request would you please rate this response accordingly.
Anonymous
  • 14 Answers
  • Posted on Nov 13, 2009
SOURCE: xrp 18v dewalt drill worked fine with plenty of
if your batts are ok and the batt connection terminals look ok you may have either faulty switch burnt off wire at brushholder or reqire new brushes
Dewalt charger normal flashing with no battery connected
please clear the contact of the battery and charger, charge the battery again. If still no help, please use a good battery to see if it is the problem of the Dewalt DC920KA battery or the charger.
My dewalt 18v drill wont reverse
most likely the switch is bad . you can find a break down and buy the part from ereplacement.com
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Need to change chuck on a 18v xrp cordless drill
go to the tip section or under my profile and I have detailed instructions on how to do this. If you need more assistance please let me know before voting. Thank you
1helpful
Dewalt 18v XRP Hammer drill cause battery to burn, I'm talking flames and smoke. Motor run in both direction.
I hope this drill is still under warranty as the battery is in serious trouble. As long as the motor is turning, it should not be causing the battery to do this. Hope this helps!
Can I adjust the slip clutch on my Dewalt XRP?
Yes it is the black ring with the numbers on it, the lower the number, the easier it slips. Higher number, less slip.
Hamer drill xrp
if the battery are less than a yr old should be a warranty
if drill DC920 or DC925 they are on recall for switch. may be co'z the battery to die. have them check at ur nearest service center.
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
