Question about HP PHOTOSMART PLUS B209A All-In-One Printer
System configuration menu hp printer - HP PHOTOSMART PLUS B209A All-In-One Printer
2 Suggested Answers
SOURCE:
FixinFax
  • 3085 Answers
SOURCE: how do i configure ip address for my HP printer
It is in the MIO section.
Answer yes to CFG?
Posted on Dec 14, 2009
Ink System has failied. Error 0xc18a0206 on HP Photosmart 6180
Press *(star) and # (hash) together on the printer and let go.
Key 1 then2 then3
Press the right arrow key until the onscreen menu shows System Configuration
Press OK
Press right arrow key until failure status is displayed
OK again
I think there was another OK after this but not sure????
Keep pressing cancel til you get back to the main menu then
Unplug from power for 1 minute then plug back in
Power back on.
Mar 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
What are the options on HP laserjet 4250 menu, i want the one to enter IP configuration
Follow these steps
Menu
Configure Device
I/O
Jet Direct Menu
TCPIP
Configuration Method
Oct 25, 2010 | HP LaserJet 4250n Printer
I need to print the page that shows the ip of the hp 4100 printer, how do i do that
Print a configuration page. Press the Menu key until you see Information menu, press the item key until you see print configuration, then press the select key. A configuration page will print and you will also obtain the network information, unless there is a problem with the network card or circuit.
Nov 04, 2009 | HP LaserJet 4100 Printer
How to print a test copy
Most HP laser printers will print out a test and configuration settings by pressing the menu button and scroll and select Informatiom Menu and scroll to select to print the test or configuration page etc.
Nov 01, 2009 | HP Color LaserJet 2600n Printer
I need to purchas one maintenance kit for HP 5100 laserjet printer. what contents should be there in manitenance kit. I got no authorised information about this on hp site
To ensure optimum print quality, the printer will prompt you to perform printer maintenance every 150,000 pages. When the PERFORM PRINTER MAINTENANCE message appears on the control panel, you will need to purchase a printer maintenance kit and install the new parts. To check the number of pages the printer has printed, print a configuration page.
To print a configuration page:
1 Press [Menu] until INFORMATION MENU appears.
2 Press [Item] until PRINT CONFIGURATION appears.
3 Press [Select] to print the configuration page.
To order the printer maintenance kit, contact an HP authorized service or support provider. (See the telephone support flyer included with the printer.)
The kit includes:
fuser assembly
transfer roller
feed rollers
necessary instructions
For more information on installing the printer maintenance kit, see the instructions that accompany it.
Sep 07, 2009 | HP LaserJet 5100 Printer
No print outcomes from hp laser jet printer.
Restore Your Printer To Factory Default Setting.
To restore the factory-set defaults
1. Press MENU/ENTER.
2. Use the < or the > button to select Service, and then press MENU/ENTER.
3. Use the < or the > button to select Restore defaults, press MENU/ENTER, and then press
MENU/ENTER again to confirm your selection.
The device automatically restarts.
Configure the printer as below :
Network configuration
You might need to configure certain network parameters on the printer. You can configure these
parameters from the printer control panel, the embedded Web server, or for most networks, from the
HP Web Jetadmin software.
NOTE For more information about using the embedded Web server, see Using the embedded
Web server.
For a complete list of supported networks and for instructions on configuring network parameters from
software, see the HP Jetdirect Embedded Print Server Administrator’s Guide. The guide comes with
printers in which an HP Jetdirect embedded print server is installed.
Manually configuring TCP/IP parameters from the printer control
panel
Use manual configuration to set an IP address, subnet mask, and default gateway.
Setting an IP address
1. Press Menu.
2. Press to highlight CONFIGURE DEVICE, and then press .
3. Press to highlight I/O, and then press .
4. Press to highlight EMBEDDED JETDIRECT, and then press .
5. Press to highlight TCP/IP, and then press .
6. Press to select CONFIG METHOD.
7. Press to highlight MANUAL, and then press .
8. Press to highlight MANUAL SETTINGS, and then press .
9. Press to highlight IP Address:, and then press .
10. Press the or arrow to increase or decrease the number for the first byte of the IP address.
11. Press to move to the next set of numbers. (Press to move to the previous set of numbers.)
NOTE To cycle through the numbers faster, hold down the arrow button.
12. Repeat steps 10 and 11 until the correct IP address is entered, and then press to save the
setting.
13. Press Menu to return to the Ready state.
Setting the subnet mask
1. Press Menu.
ENWW Ne.
If problem persist , reinstall the drivers .
Aug 07, 2009 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
32 people viewed this question
Clive
Clive
Thomas F. Schneider
