Need a code to program the hargray remote to the LG DVD Combo to work the sound
SOURCE: need codes for universal remote
JVC TV CODES:
060 026 197 069 247 923 012 065 067 141
NEED STEPS RE PROGRAM MY TV. I LOST INSTRUCTIONS. I DO HAVE CODES.
THANKS
SOURCE: GE 19GT243 REMOTE CONTROL CODE FOR A RADIO SHACK 3-IN-ONE REMOTE
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): We could not find an exact match, we think this code will work. 10054 Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
SOURCE: need universal code for 25gt240
codes 000,054,003,004,006,022,052,055,087,164,165,166,167,168,181,196,213.
SOURCE: how do i program the ge universal remote, model rc24912-e
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
