I have an ryobi ex26 gas trimmer
SOURCE: Ryobi 105r replacement line
Look at the top of the spool. Line up the two triangles/arrows by turning the inner wheel The inner wheel is a little smaller that the diameter of the spool and has grip lines scored around it. Just below those arrows, on the side of the spool there is a hole where the line would come out of. Thread the line into that hole until it comes out through a hole on the top of the spool. Then bend the end of that line over and stick it in the little hole next to the hole it came through. That will lock it in place. Pull on the other end of the line to tighten it. Now turn that inner wheel and the line will wrap around on the inside of the spool. When it stops and you can't turn it anymore, it's full. Cut the line off about 10 inches or so outside of the spool.
SOURCE: Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
SOURCE: Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two
pieces of string about 10 feet, feed line in the side holes, secure
line in hole where it comes out the bottom (it only takes about 1/4in.
to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If
it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken
inside, to clean the mechanism, or to perform other maintenance, grasp
the outer reel and unscrew the bump knob counter-clockwise. Mine is
often very tight and requires pliers to get enough leverage. While you
are in there, clean the inner reel and the inside of the outer reel to
improve feed performance. The shaft rarely needs cleaning. Do not
lubricate. After re-installing the reel, add string (0.080") as
described above.
SOURCE: New Ryobi EX26 Edger started twice and won't now.
turn the high mix screw just a little to the left it will have a letter H on one screw and L on the other
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from
the carburetor to the bottom of the tank. Leave enough slack in this
line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The
other
fuel line goes from the primer bulb to just inside the tank,
(about an inch). make sure that you get the right size fuel lines. The
plastic coupling goes on the end of this line, inside the tank. This
keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an
angle. They will feed much easier into the holes. You can than cut them
off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
