Hello Laura
Where are you trying to log in to? That is the crucial question.
Apple do that if you log in on a different device. Your normal device gives you a temporary password, and you add that to the other device. Making it work is very hit and miss and if you do it wrong it ignores further tries. You have to use your own password, then add theirs with no spaces.
Which Program? There is a difference between Burn and Copy.
Copy means you have a CD or DvD that already has something on it such as a music CD or a movie DvD and you want to copy it. The system normally reads the CD or DvD and copies the contents to disk then asks you to put in a blank CD or DvD to make the copy.
Burn means you have Data Files, Documents or Music that is already on the disk drive and you want to put it on a Cd or DvD. Normally you just put in a blank CD or DvD then either Drop and Drag, Browse or Copy and Paste the files you want on the CD or DvD.
First check your video with ANOTHER external monitor. It may be the video output of the computer turns off (It often comes from a different driver than the main computer screen). This would then be a software problem...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media.
1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds. 3.DVD drive in My Computer when clicked shows empty folder 4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot 5.Issue still persists. 6.Right now external DVD RW works perfect.
IN MY COMPUTER
RIGHT CLICK YOUR DRIVE THEN HARDWARE
AND PROPERTIES MAKE SURE THE DRIVE IS READING PROPERLY
YOU CAN ALSO GO TO DEVICE MANAGER AND UPDATE YOUR DRIVER WHAT MESSAGE APPEARS WHEN YOU TRY A DVD IN THE DRIVE
This happens when the CD or DVD reader goes out. This is a common problem with the CD/DVD combo drives. Usually it's the other way around, about 6 out of 10 times the DVD reader goes out. The drive will need to be replaced in order to fix this.
I think it is desktop DVD ROM. P3, P4, P5 are power connectors for HDD and DVD.
Upside down the DVDROM. you can see 4 screws there. remove the screws. Open the tray using a small hole in the front panel. You can easily remove the top panel now.
