How to remove cover on Electrolux model el6984a to access the cord reel?
SOURCE: can't remove motor cover for electrolux EL2050
usually there are screws on the bottom, normally 6-12 screws. Once they are out, there may tabs on the outside of the base fram, lightly use two flat head screw drivers and pull the cover away from the base.. be gentle as this plastic is thin, and could break. You will also need to make sure that the handle assembly is in the down position as the cover can get caught up in the handle when you try to remove it.
SOURCE: The cord on my electrolux Epic 6500 has been
There are two keys holding the body together, underneath the bumpers on the side of the vac. With the bag door open these keys when gripped with pliers will slide forward to release the body panels.
Before opening the vac, gently push the cord back inside the housing.
2 possibilities:
If the spool rotates and allows the cord to push in , the body must be disassembled, and the cord winder removed and the spring reloaded. This is tricky work. you will need to wind the entire cord onto the spool, then load 3.5 rotations onto the coil spring for tensioning, then reassemble. It's a bit like working on a land mine of you're new at it. Wear safety glasses.
BUT if the spool is locked from the outside and the cord wont push in or pull out, a fine , long blade screwdriver can be inserted diagonal to the body through the cord slot and with luck you can lift a cog of the spool releasing tension and the rewind will work. try that first , but be gentle . You must release the cord spool allowing a a dog ear catch cog to release inside by gently lifting upwards.
Post back to say how you made out,
Or look for an AERUS Electrolux service shop.
