Bosch 11241EVS SDS-Max Rotary Hammer Logo
A
Anonymous Posted on Jun 16, 2014
How much grease goes in a bosch 11335k? - Bosch 11241EVS SDS-Max Rotary Hammer
Parson's Repair Shop
Level 2:
Sergeant:
  • Bosch Expert 284 Answers
  • Posted on Mar 14, 2015
Bosch Expert
Level 2:
Sergeant:
Answers
284
Questions
0
Helped
226477
Points
685
I believe this tool takes 225 ml of grease, but I would strongly recommend installing a service kit #1-617-000-702
The service Kit comes with grease and all the normal wear parts (highlighted below in black circles) Service Pack 1617000702 for Bosch Power Tool eReplacement Parts
how much grease goes in a bosch 11335k? - 24642700-1tmh4chmwaodqgbdv43dd3kn-3-0.gif
2answers
Bosch 11335K Jack hammer, motor runs, hammer doesn't.
i thought id answered this, if there is an eye glass check the oil level mate, its normally below one of the handles, sometimes you can screw the eye glass off and top up
A ball bearing problem or broken piston drive rod ( its modificated by 1607000C3P) also best is to service with maintenance kit 1617000702
How do i chack bosch 60 lb jackhammer oil leval
Bosch hammer uses grease available in repair kit. Check ebay or parts house. Remove four hex bolts on the mid section of the hammer and pull off the lower end. Most of the grease goes here. There is a side cover to expose the drive gears if you hear gear noise. Depending on use, only needs grease once a year. Good luck.
Looking for bosch grease filter
Is that a carbon filter that is circular that fits over just the fan. I think I saw this at Better electrical. this web site may help find your nearest Bosch dealer http://www.bosch-home.com.au/dealer-locator.html. If you are not in Australia look for the Bosch web site in your country and look for dealer locator link.
What type of oil goes in the bosch hammer drill crank case
Not for the little handtools there are 2 different greases depending on the model.
But the average hand 5kg Bosch hammer
1 615 430 019 oil 1000ml
Bosch 11247 rotary hammer will not hammer
SAME ISSUE *****SOLVED*****
You were on the right track but needed to go farther with top description without disassembly!!
I have a barely used Hammer drill also that will rotate and run motor but does not hammer in any position.
Grease is the issue.....
Heat and sitting causes the grease to weep out & even a small amount of dust binds up the hammer drill.
******SOLUTION*****
GREASE, GREASE & MORE GREASE....
REMOVE BIT....SQUIRT IN ALOT OF THE BOSCH GREASE HOLD LOCKING CHUCK OPEN. INSERT A SPLINED BIT INTO THE HOLE AND PLUNGE GREASE IN SLOWLY SEVERAL TIMES. REMOVE BIT & REFILL GREASE & REPEAT.....VOILA.....HAMMER WORKING AGAIN....
BE SURE TO USE LOTS OF GREASE & DUST COVERS ON Bosch HD WHEN WORKING. WE ALL ERROR AND FAIL TO MAINTAIN FROM TIME TO TIME!
Feb 19, 2012 • Drills
Maintenance on a bosch pbh 2200 re sds, do i need to put oil or grease anywere in the drill?
The Bosch hammers all use a special grease for the hammering mechanisms. You should be able to buy a small tube similar to the size of a toothpaste tube, from a Bosch dealer or online. The part number is 1615430014. Here is what it looks like.
http://www.ereplacementparts.com/grease-tube-p-768150.html
Jul 16, 2011 • Garden
Good morning Sir, i fitted a complete service kit on my bosch gsh 11e but after a few moments of use it wouldn't hammer any longer, i immediately dismantled it but found nothing wrong. please note that i...
Bosch hammers work better under all environmental conditions with bosch grease part# 1615430010 or equivalent (such as hitachi, skill, or makita hammer grease). Bosch grease is light, slightly sticky with a high dropping point. If the grease is heavy and really stickey the hammering action will not be as desired and may get vacuum lock and not hit at all. Be sure to store hammer with nose pointing down to prevent hammer/anvel from slipping too far back into cylinder. In the case of Bosch hammers, more is not better. Too much grease has a negetive effect so just light application will go a long way. Good holidays
Dec 14, 2010 • Hammering
Breaker Hammers Features
power, raw strength, comfort and vibration
Top Bosch Drills Experts
Paul Carew
john h
Are you a Bosch Drill Expert? Answer questions, earn points and help others
