Kindly tell me the color code syncmaster 997df crt 19 vga 15 pinout
SOURCE: Samsung 997DF 19 in.CRT ?
Those are signs that it shorted out or probably was lugged into an outlet with an incorrect power voltage,
You need to bring it to a service center to have the Power Supply (IC) replaced.
Thanks. =)
SOURCE: VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
SOURCE: Vga cable color code of
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the
5 - DDC Return
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
