Question about Frigidaire Affinity ATF7000ES Front Load Washer
How do i fix a error 20 - Frigidaire Affinity ATF7000ES Front Load Washer
Scanner error 20?
Here is a link to help with HP LaserJet Error Codes.
Go through them, follow the procedures and you may find this useful and helpful.
http://printertechs.com/tech/error-codes/error-codes-index.php
Also, this link below, however, explains what Error 20 is and how to fix it in a "little" more detail.
--Printer Not Activated - Error 20--
I hope these help you.Regards, Mike
Mar 24, 2015 | HP LaserJet M1005 Printer
Scanner error 20 in hp laser jet m1319f
HP Printer Error Code 20 is a very common error on HP printers, which will show when your printer does not have the correct settings / configuration to enable it to be used properly. The error will generally show when you try and print a document on your HP printer, and will claim that the "Printer Is Not Activated". Although there are multiple causes of this specific error, the good news is that it is very easy to fix if you know what to do.
The error you're seeing will typically show like this:
•"Printer not activated - Error code 20′
The reason for HP Printer Error 20 to show is mainly down to the way in which Windows is continually trying to use the printer, and does not have the right settings / options for it. Printing a document with an HP Printer Error 20 is actually quite a feat, and your PC needs to have your printer set up in just the right way in order to achieve that.
Fortunately, there's a very simple and effective way to repair the Printer Error 20 in the most effective way possible - by using the steps outlined in this article.
The way to fix Printer Error 20 is to first ensure that your HP Printer is set up to be the default printer on your PC. It's often the case that the printer you have on your system will either not be the default, or will have some sort of error that will prevent it from being properly used. To make sure this problem is not an issue, you should click onto "Printers & Faxes" on your system and then right click onto your HP Printer, and select "Set As Default". This will allow your PC to use the printer every time you print,removing some confusion.
After setting your HP Printer to be the default printing device for your system, you should then look to reinstall the printer on your PC to prevent Error 20.
You can do this by clicking onto "Device Manager" and then removing the printer from your system. On top of that, you should also look to remove any third party HP printer driver software from your PC, and install it again after a restart.
-Finally, you should also use a registry cleaner tool to fix the HP Printer Error 20. Registry cleaners are software tools which can fix any of the damaged settings and errors that your system might have inside. These tools are highly popular, and are used by 1,000's of people every day to help fix a variety of errors on your system. One of the biggest problems facing the HP Printer error 20 is the way in which many people's computers will actually have an incorrect file / setting inside the registry that's leading the error to show. To ensure this problem does not cause your system to become damaged, you should make sure that you can fix any registry errors Windows has.
Or the error may come like this :
Error code 20 Problem: "Not Enough Disk Space" error message
Possible Cause: Your computer needs free disk space to complete a print job. The amount of disk space required depends on the size of the file you're printing.
Solutions:
•A large print job has exceeded the memory capacity of the printer. Verify that the SIMMS or memory cards are seated. Add more memory or simplify the print job. Remember the original HP Laserjet has only 128K of memory available, the LJ+ has only 512K and neither one is really upgradable.
•On the 5P turn the image adapt and page protect to ON or AUTO. These can be set within the Remote Control Panel. Press GO to resume printing.
•On the 5L, set the Enhanced I/O to AUTO (PCL mode) and resend the print job
•Windows XP, click Start and then click Control Panel. Click Printers And Other Hardware and Printers And Faxes. In the Printers And Faxes window, from the File menu, click Server Properties, then click the Drivers tab. This shows the settings in your printer's driver. Compare the settings in this dialog box with the ideal settings in your printer's manual. If you see a discrepancy in these settings, the printer may simply need a new driver and delete old one. You can download printer drivers from the printer manufacturer's Web site.
• Get more help. Installing a new driver won't solve every printer woe, of course, so understanding printer's manual and Windows' built-in Help system will give you an even sharper troubleshooting edge.
Nov 09, 2010 | Office Equipment & Supplies
System error 004
E004 Fixing unit failure
E100 Scanner unit failure
E246 The Counter board is left out
E676 Communication error
E677/6F-61 ROM check error
E677/6F-63 RAM error
E733 A fault occurred in the communication between the SCNT board
and ECU board/TOP signal cannot be detected
New E805 Fan failure
TRY THIS:
Cause: (1) Shorted/broken wired main thermistor
(2) Shorted/broken wired sub thermistor
(3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J301-1
(FSRTH) and J301-2 (GND).
If the resistance is not within the range between 350 W and 520 W
(room temperature of 20°C), replace the fixing film unit.
(2) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J302-1
(FSRTH2) and J302-2 (GND).
If the resistance is not within the range between 360 W and 530 W
(3) With the fixing film unit removed, if there is no continuity
between the fixing unit connectors J303-1 (ACN) and J303-3
(ACH), replace the fixing film unit.
(4) Replace the EPU board.
(5) Replace the ECU board.
Jun 24, 2010 | Canon Office Equipment & Supplies
My cd player wont work..It keeps saying error 20..I was wondering what I could do to fix it
I believe error 20 is a laser focus error, if all discs don't work unit will need repair or replacing (most likely replace due to repair cost)
Mar 23, 2010 | 1997 Pontiac Grand Am
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Does not finish cycle, gives error 20
After reading what others said on how to fix, I followed their suggestion of the coin trap, bingo, it was my problem as well. Thanks great help!
May 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
