I returned to supplier y blackberry playbook s it would not switch off. Informed that it was in aeroplane mode. How do I prevent this happening.
Being in airplane mode doesn't prevent it from switching off. All "airplane mode" does is keep you form accessing an internet connection. I just tried turning mine off in airplane mode and mine shut off fine.
How are you turning your device off? Are you using the touch screen or the power button on the top/side? If you're using the button on the top/ side, it's quite difficult to get it to turn off or even adjust the volume. (I think these buttons are useless and that they are design flaw.)
Try going up to the top right hand corner, with the device on, and touch the battery icon. It should then give you a choice between "standby", "turn off" or "restart". Other than that, I don't really know what to tell you. It's probably a good thing that you sent that one back!
Cheers and good luck, Jamie
SOURCE: I'm using the blackberry playbook to chat with a friend on FB . How do I delete these messages
same way as progran is the same
SOURCE: I want to sinc my Blackberry Playbook to my Windows 7
You need the Blackberry Desktop software installed on the computer to synch your data, music, and video on the Playbook to that on the PC. This software is available here: https://swdownloads.blackberry.com/Downloads/browseSoftware.do;jsessionid=F3B0494BF2ABF9E47D9531B30BD6E7BF.node1 . The direct link to the multi-language version of the software is: https://swdownloads.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=A2C0D61EB187AB3AFD247A852FAD3647 .
If the above links do not work, start here: http://us.blackberry.com/support/apps-and-software/desktop-pc.html and click on the Downloads for Blackberry Desktop Software. Then use the drop-down menu to select Blackberry Desktop Software Windows OS. Then download the .exe. Below you will find individual language versions. Install the software (in Win7 you need to be the Administrator).
Enable Bluetooth on the computer and pair the computer to the Blackberry.
See http://docs.blackberry.com/en/smartphone_users/deliverables/43033/1196187.jsp for more information.
Next click on Device -> Device Options and go to the General tab. Then set the "When I connect my device" items for those you want to have synchronized.
I hope this helps.
