Question about Cobra 22 CHANNEL 2-WAY RADIOS
They dont reach over a klm,they where to be 36klm
  • 50 Answers
Handheld radio range has always been way over sold. The biggest problem with handheld radios is not as much the power output but the inferior antenna system. To be able to predict radio range you must know transmitter power, receiver sensitivity, receiver selectivity, gain and height of each antenna system, distance and obstacles between. I feel sure that you are probably getting true expected range. Sorry!
Posted on Jun 27, 2009
SOURCE:
Fying from orlando to lima pru
you will need to try booking online to find this cost.
As an example KLM (Delta) will charge $150 for an extra suitcase weighing 32kg (not the 50kg you wanted, but that option wasn't there)
ref
Baggage Calculator KLM com
May 19, 2016 | Computers & Internet
Has anyone ever heard a a speedo not showing the Total klm's but everything else works OK, if so can you tell me if there's a fix for it, besides buying another one??
Dont know the MV Augusta specifically. Assuming it is not a digital speedo, is probably a stripped gear in the speedo. Probably cheaper to replace it.
Oct 30, 2014 | 2008 MV Agusta Brutale 989R
Microphone recommendation for KLM-2700
Just about any mic will do. I have used a Midland, Motorola, GE, Radio Shack and other microphones on these radio's. The mic element must be dynamic. Condenser microphones would require you to slightly modify the mic input circuit of the KLM to provide 5 to 10VDC through a 4K7 resistor to provide bias for the condenser element. It's easy to do if you have the skills to do it.
Jan 30, 2014 | Cobra Hand Microphone Wired For Klm Multi...
Mitsubishi 3000 GT 1995 Australian sold R/H drive speedo only works when I reach about 80 klm then works fine over this speed. Then when I drop below about 80 klm it wavers all over the place. I believe...
I would start with the cam and crank sensor first having them tested.Make sure it has a square wave completely threw its voltage cycle. some can break down at low rpm it is where they mostly run at. If this does not help Wheel sensors are another culprit also the IPS and OSS which is input speed sensor and output speed sensor is it a manual or automatic we need these type of details to assist you properly thanks in advance.
Sep 17, 2013 | Mitsubishi 3000GT Cars & Trucks
I want to know when to change oil a motorcyle
About 3500 miles or 5000 klm. Change the oil filter as well.
Mar 09, 2011 | kawasaki KE 125 Motorcycles
What is KLM in tejas multiplexer?
KLM is just a a link , available inside of Tejas Mux at input that is mapped to another KLM at output so as to form a transmission link
May 26, 2010 | Computers & Internet
Nortel M7324 CAP stops working after changing UPS
The buttons will all have to be reprogrammed. Try this:
Press "Feature * 2", then press the button to be programmed, and enter an extension number. You will have to do this for each button.
Alternatively, you can unplug the phone for 1 minute, and plug it back in. The lights will start to flash on the phone, and stay solid on the KLM. When the lights begin to flash on the KLM, simultaneously press the bottom 2 buttons on the left-side and the bottom 2 buttons on the right-side of the KLM. This will cause each button to light momentarily from the top-left to the bottom-right, and will program the buttons, in ascending order, automatically from the first extension in the system until it uses all available buttons on the KLM.
Hope this helps!
Nov 25, 2009 | NorStar M7324 Telephone
When car milage reached 200000 th miles it changed to klm can it be changed back
On the dash board just left of the steering wheel in the same panel as the trip counter is a switch ours has ENG and MET. Push this switch. That is what works for our car.
Oct 18, 2009 | 2002 Buick LeSabre
T-BELT light in dash of 78/79 cruiser ute
ok well its not behind dash untill later model i think from memory it should be in engine bay some where look around not sure but i know its not behind dash it may be on gear box as this only comes on when klm reach 100,000 and 200,000 and so fourth good luck
Sep 16, 2008 | 2000 Toyota Land Cruiser
Open Questions:
Cobra 22 CHANNEL 2-WAY RADIOS Logo
80 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
