SOURCE: brush roll won't turn on
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
