I think this problem might be VGA cable or colour IC of the monitor,so please if you can change these two things ,so very well, other wise you will go to the service center.
Red (foil wrapped with 1 bare ground wire) Green (foil wrapped with 1 bare ground wire) Blue (foil wrapped with 1 bare ground wire) Transparent (foil wrapped with 1 bare ground wire)All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin. Purple Yellow Black Orange White Bare braided outer ground wire. Combine ALL earths to a single point. You will have to open up the unit, to see what colors are used for the 5 - DDC Return10 - GND-Sync/Self raster12 - DDC Data 13 - H-Sync 14 - V-Sync 15 - DDC Clock Settings they are marked on the motherboard.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
