Question about Fisher and Paykel Aquasmart wl80t65c
How do I replace the hot water inlet valve on my Fisher and Paykel Aquasmart washing machine?
Top loading machine.
    Master:
  • Fisher and P... Master
  • 738 Answers
This is all one unit hot and cold together sealed unit
Posted on Apr 21, 2018
SOURCE:
SOURCE: Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Posted on Jan 13, 2009
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
SOURCE: Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Posted on May 12, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
SOURCE: Fisher/Paykel GWL10US washer. Blinking hot and
When they say replace the valve There,s a very good chance the diaphram is the valve is purferated or split (common Problem).But you can Remove the coil from this & with pointy nose plyers you can unscrew the top & inspect the diaphram If it,s ok give us a bit more info Hope this helps.Cheers.
Posted on Aug 10, 2009
Hi, my machine won't fill with water
It would only be either cold or hot that does not work. Replace the Inlet solenoid under the top panel.
You can use the same aftermarket valves for both (Original FP valves are different, cold is wildly expensive compares to hot). http://www.ebay.com.au/itm/Fisher-Paykel-Cold-24Volt-Compatible-Inlet-Valve-Part-FP420148S-/130833870254?pt=AU_ApplianceAccessoriesParts&hash=item1e764e6dae&_uhb=1
May 28, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel WL26CW1 - Error Code 49! can i swap the hot and cold valves to make it work and disconect the hot valve?? and love this site very informative, Thanx Guys..
The most common problem with AquaSmart is the pump
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Mar 19, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Fisher and paykel aquasmart fault 235
Try cleaning the INLET and the outlet valves, it is possible that the filters are blocked. If not check the wiring harness from the panel, check for moisture within the panel, if so use a dryer to warm off and test. Please estimate before any parts are replaced.
Jan 20, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
My top loader washing machine is not getting enough water-trickling only on cold water (hot is ok).
The inlet valve has failed & needs to be replaced unless you don't use hot water then you could just swap the hoses over.
Feb 18, 2011 | Fisher and Paykel IWL12 Top Load Washer
No hot or warm water, checked hot water supply and inlet screen, all OK. cold water only.
You need to replace the "hot water inlet valve". If you have have cold and hot water at the pipes and only cold coming it the valve is bad. Replace with this part.
The FixYa Team
Dec 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher/Paykel GWL10US washer. Blinking hot and cold temp buttons. I've checked the inlet valves and the cold water inlet is VERY slow. I've read alot of posts and I'm not convinced that replacing the...
Aug 10, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Aquasmart wl80t65c Logo
166 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
