Coupe
Disconnect the negative battery cable.
Remove the screw covers, screws and pushpin, then remove the door pull handle applique.
If equipped, unplug the regulator switch plate electrical connector.
Mark the position of the window regulator handle, then remove the handle using a suitable tool to disengage the regulator handle snapring.
Remove the pushpins from the trim panel.
Slide a flat-bladed tool behind each of the retaining clips and twist to disengage the clips from the door shell.
Remove the trim panel by lifting it up and sliding it rearward to clear the sheet metal.
Remove the door pull handle applique
Remove the two-piece pushpins from the trim panel
To install:
Replace all damaged trim panel retainers.
If removed, install the water shield.
Place the trim panel into position on the door and insert the door handle through the opening.
Attach the door panel fasteners.
Install the pushpins on the trim panel.
Install the regulator handle.
If equipped, attach the regulator switch plate electrical connector.
Install the door pull handle applique cover, the screws, screw covers and the pushpin.
Connect the negative battery cable.
