Maytag M7DH65B2A Dehumidifier Logo
A
Anonymous Posted on Jun 15, 2014
Operting manual for BHD-301-D - Maytag M7DH65B2A Dehumidifier
I HAVE THE BHD-301-D COMFORT AIRE DEHUMIDIFIER AND THE LIGHT KEEPS BLINKING AND IT WILL NOT RUN I DO NOT KNOW WERE THE FILTER IS TO SEE IF IT NEEDS CLEAN CAN YOU HELP THANKS
The filter is located behind the front louvers. It can be accessed by removing the water collection bucket and looking up into the bucket holder, just behind the louvers. You should see a plastic pull tab handle, which is the filter frame. If you have never removed the filter for cleaning, it may have a piece of plastic tap, which was used for shipping. you will need to remove the tape and discard it, before pulling straight won the filter frame.
The filter can be cleaned by vacuuming it or if it's really dirty, washing it it in warm water and mild dish washing liquid. Rinse thoroughly and shake off any excess water and dry the filter completely before reinstalling it. Never operate the unit with out the air intake filter in place.
Hope I was able to help you and thanks for choosing FixYa..
Ihave a comfort aire BHD-301. when i turn it on the filter lite keeps blinking and the filter is clean. is there another filter besides the one on the side?
No, there's only one filter. So be sure that you reinstalled the filter properly, so that it is making contact with the filter switch. If that checks out OK, turn the unit OFF & unplug it for 15 minutes.
After the time has elapsed plug the unit in and turn it ON. Hopefully, during that timeout, the electronics reset and reverted back to the original factory settings, If so, you can now set the controls as you desire.
I hope this helped you and thanks for choosing FixYa.
2answers
I have a comfort air dehumidifier that does seem too effective. also theer is a tube on top of the water bucket? whats that for?
That's the water collection tube, that drains water into the bucket. What's the other other problem that makes it seem, that the dehumidifier is not to effective?
Humidifier gets ice on top of cabinate. It still produces water.
Most dehumidifiers have a defrost cycle that they run through, as needed. But, apparently, your is not functioning. Eventually, yours will stop collecting moisture, if this continues. In the interim, I would suggest turning the Master OnN/OFF Switch to OFF and unplug the unit until it thaws. While it's unplugged, remove and clean the air intake filter on the front of the unit. If it's clogged it causes the unit to strain and may cause it to ice up. Once the filter is clean and the unit is un-thawed. Plug the unit back in and turn the Master ON/OFF Switch to ON and set the controls as you normally do. Hopefully, that period of being unplugged will have allowed the unit to reset itself and work properly.
I have included a link to your Owners Manual that you can download and print for future reference.
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=raw">http://www.comfort-
If the above link fails go to the following link below and click on Owner Manual, near the top of the page.
aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g">http://www.comfort-aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g
Hope this helps you solve the problem.
1helpful
I have a Comfort-Aire BHD-301 dehumidifier that runs but does not collect water. What should I do?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Shows tank is full even when empty.
Tank is not connecting with button/swith inside area where tank fits.
You may need to shim tank or use bungie cord to hold it in - the switch thinks that the tank has been removed
My comfort-aire dehumidifier #BHD-301 just stopped working. Any suggestions? Should I be doing some kind of regular maintainence?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
1helpful
Dehumidifier icing up
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Top Maytag Dehumidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
