Question about Akai LCT2715 27 in. LCD Television
My TV wont accept a signal from my cable box...
I had a slight power outage, and now my tv won't take the signal from my cable box. It just says no signal. I have tried going through the source options, but still wont work.
SOURCE:
SOURCE: HDTV
You don't mention using your SOURCE button to select HDMI.You have to put your akai in the right source selection by using the source button on the remote or the source button on the right side of the TV. I hope this helps. SW
Posted on Sep 07, 2007
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr
I have lost my manual for the lct27ta. Have you gone into the menu and setup the hdmi port?
Posted on Dec 09, 2007
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Posted on Jan 04, 2008
scottyfixit
  • 186 Answers
SOURCE: input source change on remote for tv
Are there not enough ports? You can buy port splitters to add more connections to your tv. Also, some surround sound receivers have port switchers too.
Posted on Apr 26, 2008
djchillsnyc
  • 152 Answers
SOURCE: Building power outage caused TV not to work
hello, your freinds tv has a power supply issue, it is the part that accepts incoming outlet voltages. replacing the power supply may solve this issue it is not garanteed becuase the spike or drop in voltage may have cuased other truoble in the other circut boards, the power supply couldnt handle the imediate drop in voltage cuased by a power faliure when you try to turn it back on the circut is detecting that it is not working properly so it will cause this safety shutdown it is protecting your tv from further damage.
since your area or building had the power outage this may have cuased the power supply fualt. check the voltage test points to make sure they are correct. exchanging it wouldn't hurt at this point. best bet is to get a service manual for it and be extra careful do not touch internal parts they still have stored voltages if your not electronically inclined or dont have any electronic skillz, have a service center come out and check it for you.
good luck to you guys, hope this helps
Posted on Jan 08, 2009
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
My tv is not 'seeing' any of the hdmi devices plugged into it.
surge protectors do not work very well. They dont really stop mildly high voltages. If you can plug the Directv receiver into another TV and it works, then you have a bad digital board in your TV.
Aug 15, 2015 | Toshiba Televison & Video
Motorola dcx 700 no power since a slight power
It's possible that the box is dead and need's to be replaced. One thing you can try is rebooting the box by unplugging the power cord and then plugging it back in. You can also try plugging it into a different outlet. Are you sure it's the box that's dead and not the tv?
Oct 14, 2013 | Televison & Video
After a short power outage, my new Sony Bravia KDL32BX320 (I bought it month ago) shows only a black screen, saying 'selected service is coded OR can not be decoded'. What can I do about...
Tries tv and those Cables,Satalites or Telicoms pay boxes unplug,replug it back like about an hour later.Ur tv now should do a resetting itself back to the factory setting.Those pay boxes will reboot and updated it softwares.Ur tv should have incomming broadcasting tv chanels signal know.If u still have the same problems call ur tv Cables,Satalites or Telicoms compannies for a fix.
Sep 14, 2011 | Sony KDL32BX300 32 in. TV
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Aug 11, 2011 | Sharp LC42D65U 42 in. LCD HDTV
42" 1080p Flat-Panel LCD HDTV: no signal after power outage and have tried resett...
Try hooking something else up like a playstation or dvd see if it works so you know if its the box or the tv
May 16, 2010 | Insignia 42" LCD Flat-Panel HDTV
WILL THIS TV ACCEPT THE NEW DIGITAL SIGNAL
Hello. All tv's accept the new signal. If you get your signal from satellite or cable, the box will make the signal compatible with your tv. IF you get your signal from an antenna, you may need a converter box, available from places like radio shack and staples.
Dec 23, 2009 | Televison & Video
I cannot briing in a picture. Upper left corner of picture says it is on channel 4...upper right corner "no programs availab le"How do I program TV to bring in a picture.; I am on Insight Cable.
Typically the cable box is the source of your channel programming. If you're getting the "no programs available" you need to find if that notice is from your TV or your cable box. Check the connections from your cable source to the cable box and from the cable box to your TV.
Make sure that your TV is set on the proper source selection. Most Projection TV's have several (ant, cable A, B, DVD etc) check your on-screen menu for which one and make sure the cable is connected to the proper input ports on the back of your TV.
If you disconnect the cable between the tv and cable box and still get the "no programs "...then it's your TV.. but if you lose that warning, then it's coming from the cable box... If after checking your connections, disconnect the power to your cable box and let it sit for 5 minutes and then reinsert the power to the box and see if you get a reset with signal...... If nothing after all this, contact your cable provider to check their signal to your house and also the cable box.... Hope you have quick success on this!
Dec 17, 2009 | Televison & Video
Can not get the listings for the TV Guide to load. The TV is connected to cable box and tuner with HDMI cables. When I contacted LG they stated that I need to split the cable signal prior to connecting...
Hi my name is Roety,
I can help you with your issue ,
The cable box signal is received from a round cable called coaxial cable. The guide is sent to the cable box through the coax cable. The HDMI cables sends the picture to the TV.
The Tv does not download TV guide listings , just the box does. That would be a cable company/box issue not a TV issue.
Some TVs have a built in TV guide for when you recieve signals from an antenna (not cable).
If thats what you are referring to don't bother .
Use the cable box guide .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 01, 2009 | LG 50PX4DR 50 in. Plasma TV
Ant/cable
your box might be blown out
also call the cable company to see if the outage didnt affect them
they might be out too
on the TV you might to look for setup or init setup
a model number of the tv set wouldnt hurt too
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jan 06, 2008 | Curtis-Mathis CM19011 TV
Akai LCT2715 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
