Electric Mobility Merits Electric Wheelchair Scooter Battery Charger Logo
A
Anonymous Posted on Jun 15, 2014
What does 5 flashes on revo power scooter mean?
Ower scooter wont move and power light flashes 5 times
1 Related Answer
Anonymous
  • 3085 Answers
  • Posted on Jun 27, 2010
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Status button flashes 5 times. Scooter is fully powered but will not move. Brake is off, lights work, etc.
BEFORE U RING TRY THIS TAKE KEY OUT PUT FREE WHEEL LEVER IN FREE WHEEL THEN PUT IT IN DRIVE PUT KEY IN & TRY OT. Hi again get in touch with pride www.pridemobility.com or ring them 1-800-800-8586. They might B ABLE to help cheers if the electronics r the same as celebrity put freewheel lever in drive & remove key then :::: put it back & try it out good luck
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
What are the POST codes for a revo power scooter
Go to my app and look up Flash codes for Pride Revo. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
What does 5 beeps mean In POST test on a revo power scooter
The beep code 5 normally means a Brake problem. Check wiring, Scooter Doctor App
1helpful
2answers
Power light on revo power scooter blinks 5 times and scooter won't move
hi , that's a brake issue , check the microswitch located on the brake , check the wiring connection to the brake and then the resistance, about 30 to 60 ohms ...
Regards
Rob
www.gewizrepairs.co.uk
1helpful
The manual freewheel lever will not go into gear
hi, 7 flashes implies the throttle lever (speed pot etc) is not in the correct position, other words not dead center, (PGDrives S -Drive Controller)
Let me explain , the pot in question is a 5K value and the throttle lever rests in the center of that about 2.5k give and take
If you can see the bottom of the metal stem in with the throttle lever is mounted there should be a cross head slot now that should be dead center, the slot facing you as you sit on the scooter, slightly off center will cause the fault reported.
Regards
Please rate my assistance.
Will not go know & the status light is flashing 7 times
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
1helpful
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ZJ Limited
ZJ Limited
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
