Dishwashers Logo
A
Anonymous Posted on Jun 16, 2014
Why are my dishes dry with water spots?
In the beginning my dishes came out shiney clean,I have been using my brand new machine since may, the past 2 weeks my dishes dry with horrible spots, why?
larry smith
Level 2:
Habit-Forming:
  • Expert 49 Answers
  • Posted on Jan 04, 2024
larry smith
Expert
Level 2:
Habit-Forming:
Answers
49
Questions
0
Helped
119370
Points
169
Try adding between a teaspoon to a heaping tablespoon of Baking Soda or Washing Soda to your dish washer soap.. Both seem to work. Baking Soda is actually food grade if that worries you. Not supposed to eat Tide pods and people use them in dishwashers. lol. So I have also used Arm an Hammer washing Soda. This is also dirt cheap compared to things like Jet Dry. It not only softens the water it also knocks foaming or suddsing way down. I use a small amount of Dawn or Cascade and some Baking Soda and glasses come out crystal clear. Use dish soap at own risk. It will make a huge foamy mess without Baking Soda or if you get the ratio off too much. Before I tried this my dishes came out covered in horrible white spots so bad I had to hand wash them and the spots were stubborn.
Robert Marsolais
Level 1:
Problem Solver:
  • Contributor 25 Answers
  • Posted on Sep 02, 2014
 Robert Marsolais
Contributor
Level 1:
Problem Solver:
Answers
25
Questions
0
Helped
5360
Points
29
May need some rinse agent. verify the liquid level in the rinse agent bottle.
5 Related Answers
Anonymous
  • Posted on Dec 30, 2007
SOURCE: white film on dishes
Experience : 30 years in dish washing as a professional instructing hospitals and restaurants.
It is not necesaasry to cover the heating element as long as sufficient water is present so as to not STARVE the water pump.
Listen to the sound of water serging with the machien running. If it is contant you have enough water if the sound comes and goes then the pump is serging . either lyou have a low water level or CLOGGED strainer in the bottom of the machine (inside).
you might also open the door real fast during the wash and check for water splashing and flows---- you might get wet but this way works .(wear protective eye shields)
water levels can be raised by BENDING the tab on the bottom of the float which controls water level...much like a toilet tank float.
Also finally if soap levels are too high the soap will not rinse off regardless of the amount of "rinse fluid you use.
Visit www.soapman.com
regards
soapman Bruce
Anonymous
  • 639 Answers
  • Posted on Aug 28, 2008
SOURCE: Washing and Drying lights blinking.
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Drain is clogged at the bottom or bad pump!
I would call service and get along with my life!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Mike
  • 677 Answers
  • Posted on Jun 24, 2009
SOURCE: dishes not clean, water spots
the problem sounds like hard water. go to www.dishwasherfilter.com because they have a new product out just for this problem. it will filter the water going into your dishwahser solving your problem once and for all. it is guaranteed to work and very affordable also. you will lvoe the way your dishes come out.
Anonymous
  • 10515 Answers
  • Posted on Jan 09, 2010
SOURCE: code 20 water stays on the bothom in the machine.
Error Code 20 Indicates a Problem with Drain. You need to make sure that the Hose is not kinked.Then check to make sure that Pump is fine. Filters are all set. Then, you need to Check Pressure Switch to make Sure it is not Defective. If it is Defective, change it unless the last Solution would be main PCB. But, better to Inspect, Verify and Make sure before replacing any part.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Testimonial: "thank you helpfull but need a little bit more info "
hershey46
  • Posted on Jun 23, 2010
SOURCE: Cycle isn't using Jet Dry
Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
Hi, the dishes on the top rack of our Whirlpool Quietmaster III do not dry completely, but the bottom dishes are fine. We have to re-wash the upper rack dishes; they have spots on them. Ron.
Sounds like your not using a rinse aid. Fill the dispenser with jet dry. Not only it keeps dishes spot free but it help to dry them as well.
Dishes not dry
No they don't do they. Even if you don't use "Sanitize" or "Air Dry". The water doesn't get that hot either if you haven't noticed. With the new "replacement" machine, even after it's done I can't touch the dishes for several minutes. But the LG made that little jingle indicating it was done. There must be an easter egg somewhere that tells the machine to dry. Whatever you do, go and buy Dishwasher Booster, whether your store carries "Affresh" or the Oxy Clean brand, use it every cycle with your washer. You'll thank me. Your problem probably isn't listed under troubleshooting either is it? Just hang some paper towels or a dish towel nearby and expect to dry your dishes when the machine is finished washing them.
2answers
Dishes not getting clean. I use Jet Dry &
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
5helpful
2answers
My brand new dishwasher leaves white film
The new washer is drying the dishes faster that the old one,Try setting it to no heat dry and see if that helps,if so you will need a water softener or filter for the water line to the washer.
Jul 29, 2009 • Dishwashers
1helpful
2answers
Cloudy dishes
Hi there.
You will need to get some cleaning detergent so you can clean the jets and the internals of the machine, once the clean has been done you should end up with clean dishes.
Good luck and thanks for using FixYa!!
2answers
Dishwasher runs but does not get dishes clean
1.) Confirm that the holes of the spray arms are not blocked with debris.
2.) Run a short cycle with an empty dishwasher and no dishwasher soap. Run the dishwasher until you hear it finish filling with water and begins the wash cycle. Add up to two cups of white vinegar to the water and allow to wash and drain. Feel free to do the same when the dishwasher fills again.
3.) Only use a brand name powder detergent (e.g. Electrosol or Cascade) in any dishwasher. Do not use a gel or tablet in any dishwasher. Do not fill the dispenser fully.
Test your dishwasher with a standard load of dirty dishes.
If problems continue, confirm that the heating element is working properly. The heating element is vital to getting clean dishes with modern dishwashers and DW detergent.
Please report back what you find.
2answers
Glassware and dishes getting water spots lately.
I think your dish washer is starting to go out. We have a Kenmore dish washer (unsure if the model is the same), it started with not cleaning the dishes well to not sanitizing and now it doesnt dry. We are actually replacing ours today. We we noticed that it wasnt cleaning properly (water spots, or not rinsing well) we too added Jet Dry thinking that that would solve it. We soon discovered that it didnt help at all. Hope this helps you.
Washer < 1 year old. Jet dry will not go in
as ur machine is still under warrenty u should go in touch with GE and have thos problem solved free of charge....
2answers
Spots!
Jet dry.
Jan 13, 2009 • Dishwashers
Top Fagor Dishwashers Experts
Mike Cairns
Mike Cairns
vince
larry smith
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
