Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
d
david bradley Posted on Jun 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belt routing illustrations
I need to install a new belt for my 42" STEEL deck,need a diagram can you help me?
Richard Haynes
Level 3:
Master:
  • Poulan Master 673 Answers
  • Posted on Dec 07, 2017
Richard Haynes
Poulan Master
Level 3:
Master:
Answers
673
Questions
0
Helped
208369
Points
1403
4 Related Answers
mickey813
mickey813
  • 472 Answers
  • Posted on Sep 30, 2009
SOURCE: Poulan 42-Inch Steel Deck 17.5 HP Briggs &
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
agent91
Ned White
  • 2100 Answers
  • Posted on May 04, 2010
SOURCE: 42" deck belt shredding
One of your pulleys is frozen and the belt is just going around it without it turning. Pull the belt out, remember where it goes, and find the pulley that is frozen. Get it replaced. Hope this helps.
Anonymous
  • Posted on Jul 24, 2011
SOURCE: we are needing a diagram
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Anonymous
  • Posted on Sep 22, 2011
SOURCE: Poulan 42-inch Steel Deck 15 HP Tecumseh xl/c
i need a gas tank for it do u know were i can get one.Thanks
Zoom 42 mower deck belt routing diagram
Andy, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Zoom 42 mower deck belt routing diagram Google Search
http://apache.ariens.com/manuals/00173200.pdf
How to Replace the PTO belt on an Ariens Zoom Zero Turn
Ariens Zoom 42 Owners Manual
May 07, 2016 • Garden
What is the diagram for steel deck installation for a poulan lawn tractor 42 " deck 14.5 hp ?
Do a search on goggle for the make model and deck size and you can see the routing diagram.
2answers
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
2helpful
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
What length belt do I need for my 17 HP Poulan Ride on and what is the diagram for putting it back on.?
You can find the model number under the seat by the battery. With that number you can go get the belt at a local lawn mower repair parts shop. And with that number you can find the routing on an illustrated parts drawing by going to a lawn mower/ small engine repair parts website such as partstree.com or outdoordistributors.com. If you can not find it I can tell you, but I would like to glance at the drawing to see if the deck is the one that I am familiar with, so I would need you to send me the model number from the tag.
I hope this helps you get it done.
8helpful
V-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
2helpful
Having trouble replacing a 42 craftsman riding mower belt...help Ithe old one broke off but the new one it on too tight...the replacement one is the right lenght help please
do you remember the routing of the belt? there should be a diagram on the deck somewhere - best thing to do is rout the belt while the deck is lowered, leaving the loop at the front to put around drive pully on bottom of engine. once that is all hooked up, there are deck adjusters on either side of the deck - that you can adjust to relieve some of the tension on the belt - turn the adjusters clockwise to tighten, counterclockwise to loosen - let me know if this helps or if u need more info - i have a 10 year old 42" deck tractor out in my barn and if need be, tomorrow i will walk u through - online how to adjust the deck
Need belt configuration for 46" deck of craftsman mower
there will be a sticker showing the belt routing, on the back of the deck [rear] in the middle, or on the left, top side of the deck
I have a Poulan riding mower and it has a 42" deck. I need to replace the deck belt but don't know how. Can you tell me the easiest way to replace it?
The easiest way is to find your owners manual and find the picture of the belt in there. Using the picture as a guide you can change the belt in a matter of a few minutes. Just make sure that you get the new belt under all of the belt guards or you will destroy the new belt in no time. If the pulley is flat on the running surface, it goes on the back side of the belt, if it is a "v" on the running surface, the inside of the belt goes in the "v". There may also be a routing diagram under the foot board on one side or other of the tractor. Some of the AYP units have it, some don't
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
