What i need is the deck belt size,and the drive belt size can you give me that for a poulan 14.5 lawn tractor 42 " deck ?
Http://www.lawnmowerpros.com/pdfs/poulan/hd145h42h.pdf
hope this helps
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
SOURCE: I am trying to replace my deck drive belt and do
you may have missed it but the diagram is on the deck , look closely you should see it, anyway it should look like an upside down t if you were siting and looking at it from the drivers position. you should have to remove only one pin to get the belt on and it would be on the right side of the deck
