SOURCE: kettle will not heat. Russell Hobbs corded
Check mains fuse, if ok check for voltage at kettle , with multi meter, not phase tester as these can be faulty, if you have power and no heat then it has to be the switch or the element, check and replace same. if your unsure have an electrician do it for you
SOURCE: Have you got a manual
Check if this link helps:
www.kitchen.manualsonline.com/ex/product/headline/m/???russell_???hobbs/d/slow_cooker/p/???13792
SOURCE: I have a Russel Hobbs
You will need to replace the heating element on the kettle. Here is a link to order the part.
