Contributor
- Posted on Jun 15, 2014
Re: We had a power outage, now pixma Mx410 won't come on,...
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
- Disconnect the power cord from the rear of the printer.
- Unplug the power cord from the wall outlet, power strip, or surge protector.
- If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
- Wait 15 seconds.
- If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
- Reconnect the power cord to the rear of the printer.
- Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
- Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
- Wait 15 seconds.
- Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
