My Navman S30 is failing to connect to my PC. It works as a satnav with the existing maps but when I try to link to the pc to download new maps the picture on the sat nave shows it attempting to connect but a red cross on the satnav symbol. There are no updates available. I have tried other usb sockets and switching off. Any other suggestions?
SOURCE: my navman s30 has a picture of a computerrunning a link to a USB
http://www.navman.com/in-car/europe/uk/Products/Sat-Nav-Devices/S30/Technical-Specifications/
Software likely corrupted,, Download any updates especially firmware updates at the link above. You will be required to register you device, then you should be able to download and install anything you need.
If you need more help feel free to contact me, I CAN help with this,
Thanks,
Jim
SOURCE: Navman s30 3d 2009 map update is useless
You should be able to install your old map from the DVD/CD that originally came with your Navman - you don't need a Product Key for this, even if it prompts you for one.
It appears that the commercially available 2009 map for the S-Series does *not* cover the S30 3D, just the non-3D versions, although that's not at all obvious from what's on Navman's web-site, so you have my sympathies if you bought it expecting it to work...
SOURCE: Can I get map updates for Navman N60i Satnav
yes if you are registered and if your device is not older than 12 months. otherwise you will have to pay for updated maps
