Sony Ericsson P1i Logo
A
Anonymous Posted on Jun 15, 2014
How do I reset the master pin SHS-3420? - Sony Ericsson P1i
2answers
I am trying to find a solenoid valve for the shs 800
Certainly! To help you find a solenoid valve for the Eschmann Little Sister SHS 800, there are a few pieces of information that would be helpful to know:
  1. What is the application of the solenoid valve? (i.e. what does it control in the SHS 800?)
  2. What are the specifications of the solenoid valve needed? (i.e. voltage, size, pressure rating, etc.)
  3. Are there any specific brands or models of solenoid valves that are recommended or required for the SHS 800?
With this information, it may be easier to find a suitable solenoid valve for your needs.
Resetting Master pin on rona Electronic Deadbolt lock
Google
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
Remove batteries and put them back. You will hear a long beep and a short beep.
Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
Key in master PIN and press UNLOCK button
Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
Release 0 button and you are in the Add PIN mode
Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
make model resetting lock
https://www.google.com/search?q=resetting+Master+pin+on+rona+Electronic+Deadbolt+lock
Help I need to urgently master reset the digital keypad code for my Samsung Ezon shs-1320. I changed my password and the next day it wouldn't allow me access thank you.
Here is the thing with any password reset request. Reputable CCTV and security people will not simply post a password reset for anyone to know. You need to contact a dealer or technician locally who will reset it for you. Otherwise, as you can imagine, anyone and his brother will be unlocking equipment that is not their property. Deleting files, locking out the owners, etc. So call a pro and get it done because nobody legitimate will give this information out.
2answers
I want to reset the Samsung ezon shs5120 password
Reset master Pin Samsung EZON Home Systems shs-3120? How do i reset the master Pin for Samsung Ezon Touchpad Door Lock SHS-3120. I tried to follow instructions written in the user manual but it doesn't work. I have forgot master PIN and factory reset for deleting all the users(as mentioned in manual) and setting the master Pin to default value of 1234 is not... show more
Update: I found the answer/solution
1. Press Initalizaion button on the indoor unit.
2. Press Set button for 10 Seconds.
3. Input the code "1470852369"
4. Press * Button.
Then password will be changed to 1234
Samsung SHS 5120 I bought it quite a long time ago and there is a problem recently When I put in battery it keep booting itself and keep having the turning on power sound and I cannot use the lock And...
false that word unfixable , any lock smith shop can fix it, so is false.
Just you can't
what is a
Samsung SHS 5120? it is no PC at all, is it. posted to computer repair help.
a digital door LOCK.
with card lock
and combo lock,
well gee the battery is no good, be #1 all time failure mode
the battery is 1 year life span. the manual said so.
and is true. unless high end batteries used, lithum
eight 1.5V AA alkaline
did the batteries leak acid and wreck its own box contacts?
the 9v battery trick needed. if dead lock, page 17
https://www.manualslib.com/manual/1338274/Samsung-Ezon-Shs-5120xm-Series.html?page=17#manual
Forgot my pin number .What do I do
Pin-Number for what? In most cases contact the company associated with that pin and they will help you reset it.
Feb 03, 2015 • Cell Phones
Master pin reset
There is no master PIN reset. It is meant to be a theft deterrent. If there was a master PIN reset, the thieves would have no trouble resetting the PIN and the PIN would be useless. More info about PINs can be found here:
http://www.sharc.net/gps_lost_pin.htm
Forgot My Pin Number
Do you mean security pin?If you forgot your security pin,Try default codes like 12345,00000 or else try to reset your mobile phone using master reset code.If you need master reset code visit Unlocking4free.com They will provide master reset code for Nokia and Alcatel mobile models only.
Jul 23, 2013 • Cell Phones
Need to know if we can hook a phantom powered microphone to our shs audio amplifier
Does your microphone have it's own built in phantom power? If it's just a regular mic, you should be able to connect into any MIC inputs on your Amplifier. Otherwise, you'll have to utilize a mic/line mixer to provide the phantom power your mic needs. Then you would connect your mixer to the amplifier.
Which SHS Audio amp do you have? The ones that I am familiar with do not have any MIC inputs.
- OPTiC
Master Tech
DJ PRO AUDIO
Pro Audio Equipment : Pro Audio Repairs
Top Sony Ericsson Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
August Brown
August Brown
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
