Televison & Video Logo
A
Anonymous Posted on Jun 15, 2014
How to fix regza flashing orange light - Toshiba Televison & Video
Yepi Mater
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 15, 2014
Yepi Mater
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1029
Points
What we can find many more on the site as well as sources of information. friv juegos
Orange light flashing
These blinks [Flashes] are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
2answers
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Led light keeps flashing orange, can get some sound.
It sound like you have a bad capictor on the power supply. If you take the back off your tv, you will see little round componets. These are the capictors. The tops should be completely flat. You may need to put your finger on the top to feel if they are bubbled at all. Find the one that is bubbled and replace it
My Toshiba Regza 32 inch lcd tv has a serious problem, on occasion the screnn will turn a fuzzy green color and turn itself off, usually a few loud popping noises also occur after it shuts off then the...
Model number means EVERYTHING to a real technician...
As a guess the popping noise could be arcing to ground - maybe from the inverter or one of the transformers on the inverter. The fuzzy green could be decoding the t-con board is attempting as this ground fault happens and shuts the unit off... I' would clearly have this checked before it does some serious damage. An ounce of prevention could save you pounds of cure....
William Rayburn, CET
Premium Technologies
1helpful
2answers
The TV will not turn on. Has flashing orange light
It sound like you have a bad capictor on the power supply. If you take the back off your tv, you will see little round componets. These are the capictors. The tops should be completely flat. You may need to put your finger on the top to feel if they are bubbled at all. Find the one that is bubbled and replace it.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
