Number of moles [H+] in first solution =concentration of [H+] in mol/L times the number of liters. [C1]=10^(-pH)=10^(-3) mol /L
Number of moles N1=10^(-3) mol/L * 1L= 10^(-3) mol [H+]
Concentration [C2] of second solution
[C2]= 10^(-5.5)=3.16227766*10^(-6) mol/L of [H+]
Number of moles of H+ in second solution
N2=[C2]*10 L =31.6227766*10^(-6) mol of H+
Total number of moles H+ in the new solution
N=10^(-3) +31.6227766*10^(-6) =1.031622777*10^(-3) mol
Concentration of H+ in new solution
[C]=1.031622777*10^(-3) mol / (1+10) L=9.358388878 *10^(-5) mol/L
Resulting pH=-log( 9.358388878 *10^(-5) =4.02787
pH is 4.03
SOURCE: how do i use the inv log for calculations on my sharp el-531wh
Let y=10^(x) 10 to the power of x
Take the log of both tems of the equality. You get
log(y)=log[10^(x)] where I used square brackets for clarity. But from the general properties of logarithms
log(b^(a)) = a*log(b)
Applied to our expression above
log(10^x)=x*log10
But since we are using log as log in base 10, log_10(10)=1
so
log(y)=x
We thus have two equivalent relations
y=10^x <----> x=log(y) The double arrow stands for equivalence.
If y is the log of x, then x is the antilog of y
Your question: With log_10 standing for logarith in base 10
pH=-log_10(c) c= concentration
Then log_10(c)=-pH the equivalence above translates as
log_10(c)=-pH is equivalent to c=10^(-pH)
The concentartion corresponding to a pH of 7.41 is
c=10^(-7.41)=3.89x10^(-8)
You enter it as follows
10[^]7.41[(-)][ENTER/=]
Hope it helps
SOURCE: how do I calculate pH from H+ concentration on a
You calculate the pH with the relation
pH=-log(c) where c is the
value of concentration in mol/L.
ex: c[H+]= 3.57x10^(-6)
pH: (-) [LOG]
3.57 [2nd][EE] [(-)] 6 [ ) ]
Here you have 2 change sign key press
If you have the pH, and want to calculate the concentration
that yields that value of the pH you proceed as follows
c= 10^(-pH)
Ex
pH=8.23
c: [2nd][LOG] [(-) 8.23 [)]
General shortcut.
If concentration is of the form c[H+]= 1*10^(-a) where a is an integer between 0 and 14, the pH is equal to the positive value of exponent.
Ex:c[H+]=1x10^(-5) Mol/L then the pH is just the positive value of the exponent, ie 5 because pH=-log(1.x10^-5) =- log1 -log(10^-5)=0 -(-5)=5
Above I use the rule log(axb)=log(a)+log(b) , the rule log(a^b) = b*log(a)and the facts that log(1)=0 and log(10)=1, the last being true if log stands for log in base 10.
