Cannot send pic messages
Hi
Have you checked the file size of the picture you are trying to send? MMS format does not support large files so that may be the reason your are not able to send it.
Also you can contact your carrier to check if you have the MMS service available on the plan you have with them and if the proper Access Point Names have been set up on the phone.
Regards,
Gaby
Motorola Support.
SOURCE: RAZR V3XX - sends my texts as MMS, rather than SMS...
I had this same problem and called Motorola for support. The solution is to clear text/mms message inbox and outbox. The default setting on my phone was to never clear the inbox but I changed that to remove messages when they are 10 days old, I have not experienced the problem since.
SOURCE: Phone Sending MMS Messages as Default
The phone allocates a certain amount of storage for messages on a whole. Even though there may still show space available for text messages, you have hit an invisible "limit" and the phone is now defaulting to MMS messages because there is "room" there. Delete a fair amount of messages and you should be able to start sending regular text's again.
SOURCE: Not able to send or receive MMS/Pictures with Raz3.
there's nothing wrong with the phone. get the settings from the service provider
SOURCE: MY MOTOROLA RAZR 3XX USED TO SEND MMS MESSAGES TO
Have you tried deleting your inbox and outbox. Sometimes RAZR phones have problems with the texting and email when the number of text are alot.
