GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH Logo
A
Anonymous Posted on Jun 14, 2014
Model # FUF17DACWH Freezer is leaking water
Is leaking water on the floor, can this be stopped
tractorman44
Level 2:
  • Expert 484 Answers
  • Posted on Dec 01, 2014
tractorman44
Expert
Level 2:
Answers
484
Questions
Helped
205771
Points
843
After the defrost mode, the water from the melted frost or ice should go down the drain at the bottom back of the freezer compartment. That drain is probably plugged with some gooey gunk. If its an upright freezer, there will be a hose clamped to the back that comes out of a plastic fitting.. detach it there and 'fish' into the plastic fitting with a short piece of wire then blow into it to dislodge whatever may be there. Blow downward on the hose as it too could (probably not) be plugged between there and the drain pan under the bottom of the refrigerator.
Severe cases require that the freezer back be removed and the drain thoroughly cleaned. That gets real tricky, but its doable. Ice makers in the way complicate the process too.
1helpful
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
How do I stop freezer from leaking water
A drain plug is a small hole inside your fridge to allow for moisture to escape. The reason its leaking water is because its not cooling the water to ice or its defrosting the ice to water. make sure the door closes shut and turn it up a bit as it has been very hot recently
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 • Freezers
3helpful
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Frigidare Model No. FFU1464DW2 is leaking water on ground floor, can you tell me where to find the drain pan and what is causing this? Many thanks.
Most likely it is leaking because the drain in the back of the freezer is clogged. The most likely source of excessive water drainage is a bad door seal which causes frost to build up.
4helpful
Water leaking onto the floor from freezer drain...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. .
Sep 20, 2009 • Freezers
Is a Kenmore Elite Upright Frost-Free Freezer supposed to have water leaking from underneath it? Would this be the water accumulating from the "defrost cycle" on it?
Is the drain pan underneath overflowing? If so the water filter may be clogged and the water leaking past it to the pan. The normal amount of water from the defrost cycle shouldn't fill it up. The condenser fan usually evaporates the water by blowing the warm air on the pan.
There could be a leak because or the defrost drain being stopped up but this usually comes out the bottom of the freezer door.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 16, 2009 • Freezers
I have a Kenmore upright freezer-model LFFH2067DW2 -the red light has been on for at least 12 hours and the freezer is defrosting-water is leaking on the floor-there is a vent insidethe freezer and the...
I was made aware of your concern and would like to offer a few ideas you may want to consider. Water dripping down is not a leak during defrost condition as this would be the ice melting. Normally, there would be a drain hose specifically to channel the melted ice/water to a drainage system. The amount of water would then be proportional to the amount of ice melting as with the length of time to completely melt, drain away.
Perhaps you could check the filter/drain screen as well as the drain opening for any blockage/clogging. You could also try checking the same on the drain hose as well as for possible kinks. Additionally, there would be a sensor behind a boxy cover that triggers the system back into operation. If there is still melted ice/water inside the freezer, then the sensor would prevent the unit from turning on completely. You may want to check this sensor and verify that it is dry.
An exploded parts diagram would help you identify/locate the above mentioned parts.
Good luck and thank you for using FixYa.
Top GE Freezers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
