SOURCE: My weed eater will not start
Sounds like the carb or gasket around the carb is leaking allowing the pressure to blow by when you press the primer bulb. If its not air tight it will not pop back out. Check your carb and surrounding gaskets and check for a leak.
joe
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
SOURCE: Fuel line size for troy built TB20CS weed eater
You probably have found the solution by now I would assume... TB won't tell you this because they want you to buy their stuff..
You probably are looking at the 0.08" diameter that's just a bit smaller than the 3/32". Hope this helps....
SOURCE: I need to down load the ower manualfor troy bilt
here is the manual. Just click the file to download instantly.
1. 769-04481_TB539E_Operators_Manual.pdf
Please don't forget to give this answer a four thumbs up rating.
Thank you for using Fixya.
Alp
SOURCE: i need to know what
Hi jo6616...
Use a good grade of 10W30 non-detergent oil in your weedeater.
Free answer....Please take time to rate me
