Was using vaccum and after about 25 minutes vaccum just slowed down and stopped working i then turned it off and after turning it back on it worked for like 2 seconds and die out
SOURCE: DeWalt DC500 wet/dry vacuum
I had the same problem and traced it down to the on/off switch. I sprayed some electical contact cleaner down inside the switch and now it works normal. Hope this helps.
SOURCE: My Dewalt DC500 portable vacuum suddenly stopped
this vacuum is prone to battery contactor problems. Check for bent pins or (more likely) corrosion. Check batteries and radio.
SOURCE: My Dewalt dc500 only works on AC power (plugged in
Check battery contactor on the vacuum and on the battery. It is a common problem on this vacuum. Check for bent pins and corrosion.
