My tv keeps going black and the sound shuts off . then about 30 seconds later the picture and sound comes back. it does the same thing every 30 seconds . the light stays green.
To change a ballast board its a bit of work and a tear down to get it in there . but first lets review your problem .
its cycling off every 30 seconds . id suspect a defective lamp or a power supply problem since it sounds as if the ballast board does fire . that's assuming that you do see something come up on the screen when it attempts to start if a ballast has failed it usually will make a noise or the set would almost go into a shut down . also how many blinks and what order are the events happening ?
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: KDF-E60A20 Going on and off by itself..no blinking lights
it works!! First i took off the front panel. Just check your manual
for instructions, very easy to do. If you do not have a manual just
down load one from google.. The instruction are easy to follow. The
screw they have you loosen with a alan wrench is attached to the
plastic, so you do not have to worry about dropping it inside the tv.
Removing the lamp was simple. once out you will notice on either side
are two small mesh screens. One of mine was 80% blocked with dust, the
other side was only 30-40% covered. I used a vacuum to remove the
blockage, i did not want the dust and dirt to go inside the bulb. i
then cleaned all around the lamp. Reinstalled, and we are go to go.
The kids are happy and i am happier since my wife not be buying a new
TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did
turn off my TV, then turned on. I nothiced a red blinking light. Mine
flashed 5 times. After some reserch, 5 times is video related, bulb or
video board. google red flashing light with the model you have and you
will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
SOURCE: Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
