SOURCE: need to replace a clutch cable
i need a picture or explanation, how does the clutch spring attach
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
SOURCE: Craftsman 42 '' 19.5hp lawn tractor gear shift
Sounds like your drive belt may have came off or it needs to be replaced. Take the battery out from under the seat to see if belt is still around transaxle. Sometimes it will jump off when doing a lot of starting stopping
Testimonial: "Bang-on, Barny. Many thanks."
