Dell Latitude D610 doesn't have a wireless switch but to turn on wireless you will need to hold down Fn key + F2 key. Check if wireless is enabled in BIOS (F2 at startup) by moving to Wireless-->Wireless control--> make sure its set to Fn+F2/App--> move down to wireless devices and make sure it set to on and then save the settings.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
The Latitude D610 does not have a wireless button.
You can use the wireless button or HP Connection Manager (select models only) to turn on and turn
off wireless devices.
NOTE: A computer may have a wireless button, a wireless switch, or a wireless key on the
keyboard. The term wireless button is used throughout this guide to refer to all types of wireless
controls. Refer to the Getting Started guide for information on identifying the location of the wireless
button on your computer.
To turn off wireless devices using HP Connection Manager:
? Right-click the HP Connection Manager icon in the notification area, at the far right of the
taskbar, and then click the power button next to the desired device.
- or -
Select Start > All Programs > HP > HP Connection Manager, and then click the power button
Not knowing the model of your unit, I respond with a general answer:
Using the wireless controls
You can control the wireless devices in your computer using these features:
?? Wireless button
?? Wireless Assistant software (select models only)
?? HP Connection Manager software (select models only)
?? Operating system controls
Using the wireless button
The computer has a wireless button, one or more wireless devices, and two wireless lights. All of the
wireless devices on your computer are enabled at the factory, so the wireless light is on (blue) when
you turn on the computer.
The wireless light indicates the overall power state of your wireless devices, not the status of individual
devices. If the wireless light is blue, at least one wireless device is on. If the wireless light is amber, all
wireless devices are off.
Because the wireless devices are enabled at the factory, you can use the wireless button to turn on or
turn off the wireless devices simultaneously. Individual wireless devices can be controlled through
Wireless Assistant software (select models only) or through Computer Setup.
check chap.2, page 22 in this manual:
http://tinyurl.com/3czcyss
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks,
Joe Diaz, Nashville TN.
De Cayey, P.R.!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Button on the front of the notebook:
Switch on the front of the notebook:
