SOURCE: hotpoint build in dishwasher will not drain hose not frozen or pl
hello sir you must have a clog at the drain valve or tubing where it enters sink connector alo makesure your drain tubing is not kink thanks from gilles
SOURCE: My Hotpoint HDA3420Z dishwasher is not draining. I
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Dishwasher not draining issue usually occurs due to
kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for
any visible clogging, remove if present. If no visible lint is present then
remove then turn off the dishwasher and remove the drain hose and check for any
visible clogging. If it's still not visible then the drain filter or drain pump
is clogged and you'll need to clean the drain filter and drain pump. Also,
check for any food pieces stuck near the pump impeller. Please note that
dishwashers don't drain out the complete water such that heating element
doesn't overheat. Hope this helps... Please post back for any further
assistance.
Daniel
