Question about Frigidaire Refrigerators
My freezer is collecting water in the bottom just below coils how do i repair
I think drain is clogged can't get a tube to pass in the drain. Should a tube be able to pass in the hole for model #frs6r4eq4 and could it be that frozen
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRS6R4EQ4 is collecting water in the bottom of the freezer, below the coils. I also see that you think the drain is clogged. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water is collecting. Hope this is helpful.
-Best Regards-
WP
Posted on Jun 17, 2014
SOURCE:
SOURCE: Water in Freezer bottom
drain line is blocked check bottom tray if is collecting water if not drain line blocked
Posted on May 13, 2007
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
docjohn174
  • 943 Answers
SOURCE: CLOG DRAIN FOR REFRIGERATOR
Hi, thanks for the question. these new ,or older fridges have the drain tube, between the walls of the fridge , and what happens is the water in that drain tube freezes. so the water in the defrost cycle ,cant go down to the drain pan. to repair fridge must be turned off. for at least 24 hrs. insert a small plastic tube, from the drain tray up to the freezer, an blow up the tube to clear. thanks the appliance doc. please rate my answer thanks..
Posted on Oct 08, 2008
MNTECH
  • 1543 Answers
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Posted on Jan 06, 2009
Water is leaking and collecting under the vegetable drawer. I took out the drawer and saw that the plastic drain tube seemed clogged. But I can't figure out how to clean it or if this is the problem/
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 20, 2011 | Sub-Zero 650 / O Bottom Freezer...
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Water collecting at bottom of freezer compartment
Drain system is clogged.
Clean the drain tray and drain line in the back of the freezer section, located behind the back cover and underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vla
First Choice Appliance
Sep 16, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
Hope this helpout.......
Jul 29, 2010 | Refrigerators
Water is collecting in the bottom of the refrigerator below the drawers. Water was also in the lunch meat drawer.
Your freezer defrost coils are probably frozen. Or the drain tube is plugged. Remove the rear panel from the freezer and defrost the defrost coils if necessary. Make sure that the drain tube underneath the coils is not plugged with ice or other foreign matter. You may have to thaw out the tube. If you don't make sure that the tube is clear, excess condensate will continue to drain into the fridge. Good luck!
Sep 21, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Water collects in the bottom of my LG LRTP1231W
Some units don't have a drain tube. The water flows down the back of the fridge into the bottom and it just makes a mess. It has been a problem ever since they started going "Energy efficient". The drain was a hole and they had to close the holes. If you're lucky enough to have the drain, it will be located inside the back wall of your freezer. The inside walls must be removed. The drain will be in the drip pan, below the freezing coils (fins) in the back of the freezer.
Sep 05, 2009 | LG LRTP1231W Top Freezer Refrigerator
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Freezer coils freezeup fresh food side gets warm
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Oct 07, 2008 | Frigidaire GLRS264ZA Side by Side...
Refrigerators Logo
42 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
