My S Video from laptop works with TV however no sound on TV
No, S-Video is video only. Look for the Audio output jack on your computer (usually its a lime green earphone hole). you will need a 3.5mm to RCA Stereo output wire, and attach the RCA audio to the AUX input of your TV, and then hook it to the Earphone/Speaker output jack on your computer. Then you will have to set your computer volume at about 75% (not all the way up, but more than halfway up). Then you can adjust the volume on the tv set. (just fyi, if you have bass boosting on the COMPUTER, turn that off, as well as any Equalizer or BASS/TREBEL booster. Set your mixers and boosters to NORMAL for best sound. not doing so could produce popping or scratching in the sound from the TV, also, if you have your PC volume higher than 75% that can also cause popping)
