Receiver got hot now there's no volume
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button,
press and hold the STANDBY/ON button
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
OK? shows in the display.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
and I'd evaluate the speaker load you're presenting to make sure it's effectively higher than 6-0hms per speaker channel.
