Casio fx-300ES Calculator Logo
A
Anonymous Posted on Jun 14, 2014
Unable to use the fractions button?
The symbol doesnt come up
1helpful
CASIO fx-9750GIII: Convert decimal answers to complex fractions?
to save time, I would suggest switching calculators and also recommend using an online scientific calculator to reach your goal. If the manual for your device is bad, you can look into getting a new calculator. Thank you.
1helpful
Where is the division key on the keyboard
You can either use the slash key / or if you are using Word you can insert am equation
At the top of Word click the insert button, third from the left.
Then on the far right click insert equation. There you have an option to put in almost any mathematical symbol. You could use either the division or fraction sign.
To see a stacked fraction, set the Input/Output mode to MathIO. Press [SHIFT][Mode] (SetUp).
My student has this the casio fx 300es, and needs pi to show up as a number not as the pi symbol. How do we do this?
The calculator has two Input/Output Modes: The MathIO and LineIO modes. Line IO is the old input mode where all symbols are written on a single line. MathIO permits fractions to show as they would in a textbook (a horizontal fraction bar and two squares, one on top and the other at the bottom. Pi can be used as Pi and irrational square roots are displayed with the root symbol. etc,,
If you are in MarhIO and you get a result with fractions, radicals, or pi. you can readily convert it to its decimal approximation by pressim the SD key. If you enter some expression with fractions and radicals and you do not want the result displayed with fractions or radicals you press SHIFT = instead of =,
Now if you do not care to have ANYTHING displayed as a fraction, radical or with PI, just set the IO mode to the old LineIO.
To effect that, press SHIFT MODE to enter the SETUP. Select 2:LineIO. From that moment on you will no longer see a fraction, nor a radical nor PI, e,
If you ever reset the calculator, the MathIO mode will be restored as default IO mode.
1helpful
Every answer to even addition problems are displayed as fractions. We have tried everything.
To convert a single result from symbolic (fraction) to decimal, press the S--D button. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
I'm trying to do fractions on my casio fx-300MS S-V.P.A.M. can you help me
if you need to use fractions, look at the symbol the second button beneath the RED ALFA button.
1helpful
2answers
How to convert a fraction into a decimal
First put the calculator in degree mode.
To convert from fraction to a decimal number first enter your fraction or, mixed number. I'll convert a mixed number to a fraction first since, I don't have a key for the symbol that shows that a number is a fraction on my keyboard. Example: [3][A b/c][1][A b/c][2][A b/cd/e][ENTER]
3/2 should be entered at the home screen. While at the Home screen enter, [2nd][FD][ENTER]
1.5 should now be displayed at the Home screen.
As you can see it is really just using the [A b/c] key to enter in your fraction and, [FD] key to do the converting. The [A_b/cd/e] key isn't necessary because, mixed numbers will convert to decimal numbers just like fractions do. I just don't have the key to show a fraction symbol that the calculator uses. So to show that symbol, I used the / symbol with the fraction number.
2answers
Factions
The fraction symbol is ab/c
All scientific/graphics calculators have a fraction key. Going by the picture I would assume that calculator would have it
32helpful
4answers
How to do fractions.
A fraction is just division of the numerator by the denominator.  So all you have to do is enter the division symbol in place of the fraction bar.  If you are trying to enter a mixed fraction: for example 3 3/5 enter: (3+3/5) were the / is the division button or your calculator.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
