If you're having trouble getting the Toro 360 quad steer to track straight from front to back wheels, there are a few potential issues that could be causing the problem:
- Wheel alignment: If the front and back wheels are not properly aligned, this can cause the steering to be off. Make sure to check the alignment of both the front and back wheels, and adjust them as necessary. - Tire pressure: Uneven tire pressure can also cause the steering to be off. Make sure all tires are inflated to the recommended pressure. - Steering linkage: Check the steering linkage for any signs of wear or damage. Replace any worn or damaged parts as necessary. - Steering gear: The steering gear may need to be adjusted or replaced if it is causing the steering to be off. - Suspension: Issues with the suspension system can also affect the steering. Make sure to check the suspension for any damage or wear, and replace any damaged parts.
If you're still having trouble getting the Toro 360 quad steer to track straight, it may be a good idea to take it to a professional mechanic for further inspection and proper fixing.
If you are having trouble getting both front and back wheels of your Toro 360 Quad Steer to line up straight, there are a few things you can try:
1. Check tire pressure: Uneven tire pressure can cause your wheels to misalign. Make sure the tire pressure is the same on all four wheels. 2. Check alignment bolts: The Toro 360 Quad Steer has alignment bolts that allow you to adjust the alignment of the wheels. Check to make sure the bolts are not loose and adjust them if necessary. 3. Check steering linkage: The steering linkage may be worn or damaged, causing the wheels to misalign. Inspect the steering linkage for any signs of wear or damage, and replace any worn or damaged parts. 4. Check for bent parts: The wheels may be misaligned due to bent parts, such as the tie rods or axle. Inspect these parts for any signs of bending or damage, and replace them if necessary. 5. Seek professional help: If you are unable to adjust the alignment yourself, it may be best to seek the help of a professional mechanic or service technician who has experience working with Toro 360 Quad Steer equipment.
1st with mover off verify that both handles move same amount forward , I use a string to measure them , they both have mechanical stops that do bend and move sometimes
second locate control body valve , (thing that handles connect too) there should be a pump pressure adjust (allen key) on the side of this your gonna need to make small adjustments and try it , is difficult to do if you don't have a lift to elevate wheels of mower (but is possible without ) but takes patience
You dont adjust the belt,you adjust the cable that moves the pulley into the belt. There will be a small single bracket close to the engine side of the mower that holds the cable in place. Simply loosen bracket and move cable until pulley contacts belt enough to engage self propel.
