so what had been hapening is that it could die depending if it was the battery that could aftfect with this. 24 volt battery, and can be ridden for up to 45 minutes after battery charging. The charge time recommended for this Razor electric scooter is about 10-12 hours after each use.
<utube src="JKzj7Bu2Ink"></utube>This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
You have to make sure that the batteries are still good. Take a volt meter and read the levels that the batteries are producing. If the levels are too low, then your batteries may have sat, unused, for too long. SLA (Sealed Lead Acid) batteries will generally lose their charge holding capabilities if you leave them in storage for too long without charging them.
YOu can get replacement batteries at this online Electric Scooter Parts Store: http://www.partsforscooters.com/s.nl?partner=URBANSCOOTERS
