Question about Frigidaire FAC126P1 wall/window Air Conditioner
Just purchased a 15000 btu 110 Frigidaire window unit and we love it. However, since the rear of the AC is actually on the back porch, the water from the AC runs down the wall and on to the floor. We could not find in the manual anything about a place to attach a drain tube nor did we see evidence of one on the unit itself. Our house is wooden and susceptible to termites. How do we funnel the water from the AC to the ground? Is there a separate attachment for the AC? How do we funnel the water from the AC to the ground? Thanks,oliver f. mckinney
    Top Expert:
  • Frigidaire Master
  • 53,745 Answers
Window units slide into an outside frame section
there is a hose attachment area at the back of the ac unit proper that a hose can be attached to
and there should be a section in the frame that allows the hose to be fitted to that ac unit proper
the unit should be mounted so that it actually slopes slightly down at the rear so water can collect at that drain point
there are adaptors that should have come in the packing box for hose attachment
if not, many people use white poly piping or electrical conduit with suitable elbows to collect the water at the hole and pipe it back to the wall into a bucket and the collected water used to water plants and gardens
Posted on May 02, 2017
SOURCE:
  • 57 Answers
SOURCE: window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
Posted on May 20, 2008
  • 398 Answers
SOURCE: Can I mount a Samsung AC unit thru wall rather then window?
as long as the vents are completlyeyt covered. and cove rit in winter
Posted on Mar 18, 2009
SOURCE: i am getting alot of water leaking out of the unit.
I live with my husband and three sons in a house that we almost never succeed in cooling enough every summer. But a few months back, my uncle mentioned that he had recently purchased a new model of air conditioner by Plasma Cool called Plasma Cool Portable PC-14E that required no draining and came equipped with technology to remove most of the humidity from the air. We checked this ac out at his home, and the next thing we did was researched all the no drain acs with evaporative booster out there in the market to see if there was anything better than the one my uncle had. But the only one that met our needs and budget was Plasma Cool Portable PC-14E. At 14,000 BTU, this ac is 40-50% more powerful than similar acs in the market and covers upto 500 sq. ft. Look for this product on www.plasmacoolportableac.com which lays out the features and specifications in easy and comprehensible fashion without coming across as trying too hard to sell you the product. We just finished the 30 day trial period, and now own the ac. We are very satisfied and are considering purchasing another unit soon.
Posted on Jul 29, 2009
  • 193 Answers
SOURCE: water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Posted on Aug 18, 2009
co7196
  • 3433 Answers
SOURCE: Constant leaking water
The unit must be level and the hose lower than the machine. -Good Luck-Ned_
Posted on Aug 23, 2009
Frigidaire model FFRE1033SI window airconditioner tilt problem.
Water going outside is the important part. The hole is not necessarily the drain, the angle at most is an eyesore!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 19, 2017 | Frigidaire Heating & Cooling
Why is e5 showing on my 15000 frigdare window unit
Ive seen ES, in two sites http://www.doityourself.com/forum/air-conditioning-cooling-systems/532071-frigidaire-ac-window-unit.html
http://www.searspartsdirect.com/window-air-conditioner-repair/error-codes/frigidaire-window-air-conditioner-error-codes.html So I'd tend to agree with the majority.
Mar 14, 2015 | Heating & Cooling
My ac window units are not draining water and creating mold in my house
Check the drain tube between the evaporator side to the back of the unit. It may have a packing plug installed. If there is one remove it or clean the drain tube.
Jul 23, 2014 | Frigidaire FRA08PZU1 8,000 btu Window AC...
I have a dometic rv unit 15000 btu what is the amp draw?
For an RV 15000 BTU air conditioner the size being maximum for 115 volts ac you will need to have a independent circuit breaker for it only and rated at 20 amps. The average amps depends on serveral factors like actual supply voltage somtimes 110 to 120 volts and wire size and length feeding the air conditioner. To answer your question the average Amps will be near 13 Amps. Click Here=>
Dometic RV Air Conditioner Installation Manual and Specifications
Click here for a photo of the Electrical Spects.=>
Dometic_RV_Air_Conditioner_Electrical_Specifications
If you have any questions I will be here to answer them for you, Thanks, Sea Breeze
Aug 19, 2011 | Dometic Rooftop RV Air Conditioner
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
Water doens't drain properly and sitting there,
Aug 18, 2009 | Frigidaire Heating & Cooling
Two brand news ac unit out of box will not work
get a yellow tester from homedepot, it has three lights [ amber amber red ] hat tell you what you have at the plug. takes out all the guess work. you will love
good luck
saw
Jul 09, 2009 | Heating & Cooling
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Frigidaire FAC126P1 wall/window Air Conditioner Logo
    1,241 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Donni Steen
    Bill Long
    Pete Norton
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
