Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
A
Anonymous Posted on Jun 14, 2014
Bosch clothes washer 300 error code 04 - Bosch Logixx WFT 2806 Front Load Washer/Dryer
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Mar 02, 2009
SOURCE: bosch 300 series washer// led code E04
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Anonymous
  • 3 Answers
  • Posted on Aug 16, 2009
SOURCE: My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Anonymous
  • 414 Answers
  • Posted on Jul 12, 2010
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Anonymous
  • Posted on Sep 21, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Nov 26, 2010
SOURCE: Have a BOSCH 300/500 series washing machine.
The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
What is error code E04 on hoover washer
E:04" on the washing machine. Check to ensure there is no water in the tub. This is a common error often associated with too many suds blocking the pump. It is caused by using the wrong laundry detergent which is not designed for high-efficiency washers. You can adjust your use of detergent and reset the machine to eliminate the error code.
Read more : http://www.ehow.com/how_10038363_reset-bosch-washing-machine-error-e04.html How to Reset Bosch Washing Machine With Error 04 eHow
Bosch nexxt 300. How do I correct err 04?
If the error code is a F04, then it means that you have a motor fault.
What does fault code e04 mean
There are many brands of washers and the error codes are different.
What kind of washer do you have. Brand name and model number.
Open door and look around the frame for the model number.
Here is a link to e04 on a Bosch washer.
Repairing 04 Error on Bosch Washer
2helpful
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
2helpful
2answers
Bosch series 300 washer: E:04 error; how to remove pump cover
You can get that cover off, by prying it up at the bottom and spinning the thing clockwise. then there is a large hand turnable plug inside.
Once you turn it water will start leaking out, you'll have to get in and pull out the crud from the pump screen there to clear the jam. Good luck!
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
