It going to require a technician because that code series deals with NVRAM which can only be upgraded or replaced by konicaminolta technician who have access to secure server for firmware upload procedures
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: renolio
your problem maybe caused by a thermistor near the pressure roll in the fusing unit (the red roll).
Try the follow procedure and if it doesn't fix call minolta service.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
SOURCE: Where can I get instructions on how to replace the
Open right door and remove two screws holding the belt in. Lift and remove the transfer belt. After replacement run gradation.
SOURCE: How to make nvram recovery
You'll need:
1- 1 compatible CompactFlash card (not all of them work, you'll need to try for yourself)
1- 1 CompactFlash card reader/writer
1- This tool
There should be a document enclosed with that tool explaining the process, it's fairly easy and quick. Notice that the procedure will solve some NVRAM related problems and also some network card related problems, but it will not erase your counters.
