Health & Beauty Logo
A
Anonymous Posted on Jun 13, 2014
What flash codes mean - Invacare Supply Group Health & Beauty
gnsdance97
Level 1:
New Friend:
  • Contributor 68 Answers
  • Posted on Jun 25, 2015
gnsdance97
Contributor
Level 1:
New Friend:
Answers
68
Questions
0
Helped
36705
Points
82
They are diagnostic codes to help troubleshoot a possible problem with your wheelchair. The lights blink in patterns. You have to count the number of blinks and what color they are.
I have a 2003 ford windstar with the airbag light on. Flashes code 35. Is this something I can fix?
Codes 32 to 35
These codes are signaled by three flashes, a two-second pause and the number of flashes that corresponds to the second digit. Code 32 (triple flash, pause, two flashes) means the driver side airbag has a circuit open or with high resistance, Code 33 (triple flash, pause, two flashes) means the passenger side airbag has a circuit open or with high resistance, Code 34 (triple flash, pause, four flashes) means the driver side airbag has a shorted circuit or one with low resistance and Code 35 (triple flash, pause, five flashes) means the passenger side airbag has a shorted circuit or one with low resistance.
I personally would let some one who knows what they are doing look at it. Grounding or feeding the wrong wire could set off an air bag and hurt someone.
I'm working on the 2004 Jeep Grand Cherokee 4.7 showing error codes
lashes 52 and 54 ,you do mean flashes ? What flashes ? Check engine light doesn't flash codes .
What does code 33 mean 2006 Grand Marquis airbag
Mercury Grand Marquis diagnostic code 33 Questions ...
www.fixya.com > ... > diagnostic code 33 > Cars & Trucks > Mercury
Mercury Grand Marquis cars & trucks diagnostic code 33 questions and ... 2006Mercury Grand Marquis air bag light flashes ... What does code po1151 mean.
2006 Mercury Grand Marquis air bag light flashes three ...
www.fixya.com/.../t19845434-2006_mercury_grand_marquis_air_bag_l...
Sep 3, 2013 - It then stay on. I assume - Mercury 2006 Grand Marquis question. ...What does a flashing air bag light mean on a 1993 Grand Marquis? Jul 23 ...
Mercury Grand Marquis airbag code 33 Questions ... - Fixya
www.fixya.com > ... > Tags > airbag code 33 > Cars & Trucks > Mercury
Mercury Grand Marquis cars & trucks airbag code 33 questions and answers. ... What does a flashing air ... 2006 Mercury Grand Marquis air bag light flashes.Missing: mean
1helpful
I have a 1995 Isuzu Trooper and am getting the diagnostic code Flash... Flash,Flash. I believe thet means 12. Does that mean solenoid circuit failure? And if so, what do I need to do to fix my rig?
When you flash codes on a 95 trooper..it should flash code 12 pause and flash code 12 two more times...if no other codes flash it means there are no codes stored...code 12 is basically, enter codes, beginning of codes and end of codes.
I just double checked cos 95 models were I thought allrunning the obd 2systems..but production dates after the 8th month are considered next year models..so maybe yours is a late year production. I am going to send a picture and pre odb2 code 12 is a code..hope this helps!
What is the joystick flash code meaning
It flashes a given number of times to help diagnose a problem with the mobility device. It can mean anything from a low battery to a blown controller. Each chair comes with an owners manual that shows what the flash codes mean, or they can find the codes on the manufacturer's websites.
2helpful
2answers
Service engine soon light is flashing
Have the car scanned for the code's origin. This could mean that the engine will not work as well as it should, and could cause driveability isues.
A constant service engine soon light means that a hard code exists. A flashing light means that an intermittent code exists, but it could become a hard code very quickly.
I have a 95 honda accord check engine light flash 1 long and 7 short. what does that code mean?
That means Code 17, one long flash means 1, seven short flashes means 7. The code is for the Vehicle Speed Sensor (VSS) Have it checked and replaced if necessary.
2helpful
Engine code
12 and 55. The 55 means end of code session, the 12 means no distributor reference. Both of these codes are normal with the engine not running, so do not go out and purchase a dstributor. Is there another problem with the vehicle, or did you just want to know the codes? Comment back to continue,thanks.
3helpful
What does it mean when the word "HOLD" appears blinking on my dashbord, I believe it has to do with the gears
Yes the HOLD light comes on when the computer detects a malfunction with the transmission....one quick flash of the hold light means a 01 code. six quick flashes would mean a 06 code. 5 long flashes would indicate a 50...6 long flashes would indicate a 60 code. Hope this helps.
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
john h
Steve Pack
Steve Pack
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
